Bulb Socket type standard or CK?
Old 07 Oct 2015, 11:22 am
muzicmax's Avatar
Default Bulb Socket type standard or CK?
I was wondering if the Pt Cruisers have a standard bulb socket or the CK type?
I wanted to buy some led tail light bulbs off ebay but there are 2 different types standard socket or CK socket. There is a you tube video to show how to test it to see but I don't have the light tester to check it and am too cheap to buy one for a one time use lol
Mabey someone here knows already
Old 07 Oct 2015, 11:43 am
Default Re: Bulb Socket type standard or CK?
I don't know what the hell a CK is. Can you explain what that is?
Old 07 Oct 2015, 01:32 pm
muzicmax's Avatar
It is the way the socket is set up with neg and pos areas.
Old 07 Oct 2015, 02:51 pm
Wow! I would never have guessed they'd change the socket set up. I don't know which one you have. I guess the only way to know would be to get your test light out and start checking which wire does what. It should only take a minute. Just turn the key to start, flip the turn signal lever to one side or the other and check the socket. If the light blinks on your test light, then you'll know which is which.
Old 07 Oct 2015, 06:56 pm
muzicmax's Avatar
Dam I was hoping someone would know what the Pt's have LOL
I didn't know there were 2 different types either. But if you use the wrong LED for the socket it will blow the fuse and they sell both types of LEDs.So just wanted to make sure I bought the right LED for my sockets.
Bad Headlight Socket/Wiring bjagd02 General PT Cruiser Discussions 5 22 Sep 2014 05:24 pm
headlamp bulb out but 12v ok & bulb ok? Dwummer General PT Cruiser Discussions 13 19 Jun 2012 03:50 pm
Additonal 12v socket CalzoneGolem Interior Accessories Forum 10 08 Aug 2011 06:53 pm
Light Socket thedogg001 Exterior Accessories Forum 7 22 Jan 2010 03:52 am
Antenna Nut Socket rnbenoit Sound and Security Forum 4 17 Nov 2003 12:07 am
