02 cruiser, 16v coolant leak
Old 13 Oct 2015, 10:09 am
Default 02 cruiser, 16v coolant leak
Hello everyone, this is my second post on this forum. The first one was no help at all. I am fluent with vw, and have grown to love this cruiser so any advice is appreciated. I had a leak coming from the water pump-to-radiator pipe. So I went in and did the timing belt, water pump, thermostat, and the seal for the pipe. The car is still pissing coolant out of the WP-to-rad pipe, I pulled the pipe + lower rad hose, the new seal I just installed is chewed up... That's where I'm at if anyone wants to drop in.
Old 13 Oct 2015, 11:26 am
LionPT's Avatar
Default Re: 02 cruiser, 16v coolant leak
Can you post some pics, it could help.
Old 13 Oct 2015, 11:55 am
I can't upload pictures from my phone or I would. I rebuilt the car with the new WP, timing belt, thermostat, and o-ring seal for the WP-to-rad pipe. I took it out for a drive after bleeding the coolant system... All was fine until I stopped for 5 minutes to fill my tires up with air at my local grocery store. It started pouring coolant out of the drivers side of the water pump(where the rad pipe O-ring seal is). I proceeded to take that pipe/hose off and found the o-ring seal was torn up. I have checked that the radiator is clear of clogs, the water pump is spinning properly, the heatercore is blowing very hot air. The only abnormality I found was that the lower rad hose was cold while the top hose was hot. Bad thermostat from advanced auto maybe?
Old 13 Oct 2015, 12:40 pm
Improper installation of the "O" ring, T stat would have no bearing on the "O" ring seal. I've never bothered to change that O ring unless it was leaking already.
I take it is inserted from the starter side of the water pump.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 13 Oct 2015, 01:41 pm
The original leak was from the starter side of the water pump, I changed everything else because the car is at 120k miles and appeared to be the factory original parts. When I pulled the O ring out, it had been marred on one section. I went through and wire brushed both of the surfaces that the O ring mates to. I am at the point that I do believe it was a possible bad install, due to the fact that the t stat did open and close during the coolant bleeding procedure.
Old 13 Oct 2015, 02:18 pm
Make sure the pipe that goes into it is clean and lube it before you slip it in.
Inspect it , may be cracked. My supply and return lines are rusting pretty bad.
73 Charger SE
01 Sebring flip
Old 13 Oct 2015, 02:36 pm
Thanks, I'm going to install a new seal after an inspection as stated above, and I'll try it again. If it doesn't work I'll keep updates coming to help out anyone else in this situation.
Tags
coolant, leak, water pump
Coolant Leak jjackson23 Tech & Performance Forum 5 22 Mar 2014 01:19 pm
2001 PT Cruiser overheated, coolant leak help! Jmavens Tech & Performance Forum 3 14 Jan 2014 09:58 am
Troubleshoot coolant leak: Photo of Coolant on top of engine radiator cap MarcusO Tech & Performance Forum 7 27 Apr 2013 09:16 am
Coolant Leak TimWeaver Tech & Performance Forum 6 13 Jul 2012 08:55 pm
PLz help= Coolant leak PtC06 Tech & Performance Forum 2 04 Dec 2010 02:01 am
