Special engine coolant?
Like Tree3Likes
  • 1 Post By NitroPT
  • 2 Post By rob342
Old 14 Oct 2015, 10:44 pm
Default Special engine coolant?
Sorry I'm new and couldn't find a correct place to put this questions, so I figured general discussion. I join this site because everytime I google a problem this site pops up.
I have something that holds liquid that says "special engine coolant see owners manual"... The person I bought this off must of kept this. IDK what this means or where to find it, I looked on amazon and walmart.
I have this + anti freeze, so I don't believe this needs anti freeze in it. I was wondering how to know what to put in and where to find it.
It's a 2004 automatic.
Old 14 Oct 2015, 10:55 pm
Default Re: Special engine coolant?
This can get technically complicated......
I use for myself and all of my PT Cruiser customers Zerex G-05
MJKnight likes this.
Old 14 Oct 2015, 11:04 pm
For the "Special engine" labeled cap and liquid container? And where can it be bought?
Old 15 Oct 2015, 12:55 am
Just a note, take it for what its worth, your car anti-freeze requires at least a Chrysler/Mopar compatible solution,
your choice of Pre-mixed that you add no water to or full strength that you need to add water to achieve your cars recommended freeze protection.
(Read the label) Anti_Freeze not only protects for cold weather, it raises the boiling point of water, cooling liquid, and protects the internal iron parts of the engine from rusting.
Gone are the days you have to change your hoses every three years because the ant- freeze (oil-based) softened the hoses.
You don't want to add any other (Ford or GM - ) specific Anti-Freeze with your Anti-freeze, they will clog your radiator.
Also, if you need to add Transmission Fluid, Use ATF+4 or the Mopar ATF+4 (Chrysler) brand, any others will shorten your transmissions life.
Don't use automatic transmission Fluid in your Power steering, buy the recommended "Power Steering Fluid"
Read your owners manual at least once. Your Pt Cruiser has a timing belt and components that Must be changed at 100,000 mile intervals
or risk it breaking and leaving you stranded and possible added cost for valve damage.
Hope you enjoy your Cruiser! Come back often to read the post.
(Welcome to chime in and correct me if wrong)
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 15 Oct 2015, 08:27 am
Where are you located?
Old 15 Oct 2015, 08:50 am
SW PA
73 Charger SE
01 Sebring flip
Old 15 Oct 2015, 08:58 am
Fk5 Fk5 is offline
Generally all good advice, but my power steering cap and owner's manual both say to use ATF4 in the power steering. Believe me, I wish they didn't. That stuff is expensive and it stinks to high heaven. I'm not sure if it changed over the years, but that is the recommendation for my 2003 GT.
Old 15 Oct 2015, 09:03 am
Before you do anything. Tell us what color is in yours. It may have been changed. So info assuming you have original might cause the problem we speak to avoid. all anti freeze are good. Problems come when you mix some that are not comparable with others. Color will hep narrow down what your running.
Old 15 Oct 2015, 09:34 am
I stand corrected- when I bought my used 2003 the power steering pump had red trans fluid in it and sounded like it was starving for fluid, I thought the previous owner used at+4 but it must have been another brand, I flushed my PS and used regular PS (clear) fluid and have no problem since.
Come to think of it auto trans failed at 125,000, I think they replaced the trans cooler and used another brand of fluid for it too, I think it was the pump or converter that failed, it just quit pulling. I took it apart and didn't find any damage.
73 Charger SE
01 Sebring flip
Old 15 Oct 2015, 10:02 am
i use the green stuff because it's free and i don't mind changing it every year or two. my car has a few miles on it.
what color is the stuff that's in the car now? if it's the green stuff, keep with it. it's not like draining it and refilling it will prevent impending doom
JoeX and LionPT like this.
Leaking coolant - "Engine coolant pipes"? xkey General PT Cruiser Discussions 3 01 Jun 2014 09:11 am
Troubleshoot coolant leak: Photo of Coolant on top of engine radiator cap MarcusO Tech & Performance Forum 7 27 Apr 2013 09:16 am
Engine coolant replacement Batfalcon Europe PT Forum 6 20 Dec 2012 04:44 pm
Engine coolant leak help Vicky Tech & Performance Forum 9 25 Jul 2012 04:22 pm
Special engine coolant fluid mstyler05 Tech & Performance Forum 8 19 Jun 2010 12:12 pm
