I've never had the luxury of storing one for the winter, so anything I would suggest would just be conjecture. I'll leave this to the guys that live in the frigid north!
![]() Aspire to inspire before you expire. |
In the olden days we were always sure to fill the tank up to the top. The theory was that this would not allow condensation to form and rust up your tank. Present day gas is pretty volatile and starts smelling like turpentine much sooner. At a minimum get some Sta-Bil or the like to keep the gas stable. It *might* last the season without it, but I wouldn't risk it.
I would disconnect the battery and then throw it on a charger when I was ready to start it. I used to pull the plugs or at least pull the coil wire before cranking to get the oil pressure up, but I'm not sure that is a thing anymore. I can understand the desire to keep it out of the bad weather, but most of my cars suffer more from the lack of use than overuse. If you are saving the cash by not keeping it insured, don't bother, but IMO the best method is to garage it and take it out at least once a month or so when the weather is nice. You may have to hose the bottom off, but mechanically it might be for the best. What kind of Imperial? I have a couple of the 80's coupes. One is stock the other with a Magnum 360/727. Both are suffering from being stored and not removed from storage! |
^^^Times 2 with one exception. I would leave the battery connected and put it on a trickle charger. I have 2 of these. One is for the riding lawn mower and the other for my car(s).
Schumacher Battery Companion Fully Automatic 1.5A Trickle Charger at Blain's Farm & Fleet
2005 Toyota Camry LE Salsa Red (Wife's) 2002 Automatic N/A (Mine) Inferno Red 2016 Kia Soul Plus Black |
Far as the gas. I have gas in the project that is 3 + years old. Still starts a mf runs. Caburatored engines are more problematic for the old gas thing. Of cours. Stabil won't hurt. I would just keep about a quarter tank do you ca fill up with fresh in the spring.
I live in Buffalo & storage of my PT is right around the corner, mine is stored at home in attached heated garage. Quarter tank of gas with Sta-bil is spot on, so you can put a full fresh tank in the spring. I start it at least once a month, and if possible hook up a Battery Tender charger to it, you don't have to disconnect the battery. Since we live in NY, in the spring when you go to get the car inspected, by completely disconnecting your battery the NYS computer will not be able to read your car properly, so do one of 2 things. Keep battery connected with charger on it (battery tender jr or similar) and have no issues, OR reconnect battery & you will need to drive about 25 miles at local & highway speeds to get computer to generate codes for NYS inspection computer to read properly so you can get your inspection sticker in the spring. Other then that make sure your tires don't lose air. I've stored it like this for several years & never had a problem, except the 1 yr I fully disconnected the battery. A car cover is a good idea, also place an open container with baking soda on the floor prevents musty smells. Good luck!!
![]() Last edited by DroptopPTGTCruizer; 16 Oct 2015 at 08:11 pm. Reason: grammar |
![]() Quote:
I agree that letting a car sit is worse than driving it and I do intend on at least starting the Cruiser and moving it around, at least once a month or more. Maybe take it for a short run up and down the street. My Imperial suffered from disuse in the winter and the only place I had to store it was a metal shed with a dirt floor. ![]() Here it is the one time I was able to take it to Chryslers at Carlisle. I found a great set of Turbine wheels from a Cordoba LeBaron that had the Imp Eagle in the centers. Man - I sometimes miss that car. LeBaronWheel12small.jpg
![]() ![]() ![]() 2004 Limited Edition Platinum Series, Graphite Metallic, Standard Turbo, automatic, RBQ radio with Sirius Radio & 6 CD changer, VentShades, chrome exhaust tip, door spears, grille inserts, door lock pulls, bright pedals and steering wheel spokes. Red spoiler from a donor PT. Known as: "The RATMOBILE" I bought it Apr 28th, 2016 with 62,400 miles on it. |
![]() Quote:
My PT is an '03, but is also inferno red. I don't think I've parked it at Carlisle. We took my Dad's SRT Challenger the last time or two. I have to get my 'cuda or the Imps started, but that brings us full circle to the storage. The 'cuda gas is ancient and the tank has been rusted for years. The Imperials should be okay, but the gas is going on ten years old, so I want to drain and replace. Should be easier since they all have electric pumps that can be jumped. The 'cuda will be more of a siphon/vacuum job. PS: I am pretty sure that the "Imperial Eagle" is actually the symbol for LeBaron Coachbuilders. That is why it used to be on Imperials and then all the dozens of incarnations of LeBarons. |
I'd trickle charge the battery monthly if you don't have a battery tender.
If you can get gas w/o ethanol, I'd fill it with that and add stabil regardless. Here are a couple of tips I got recently from a restoration shop: Fabric softener sheets inside the car, trunk, glove box, on top of tires - more the merrier and the smell is not nearly as offensive as moth balls. BUT if you are in a place where critters hunker down for winter, try the moth balls under the car or a ring around the car. DO NOT sprinkle moth balls around inside the car, takes FOREVER to get the smell out of carpeting (we know, did this once) ....better to just set an open box inside if you feel the need. I hope somebody can help me get the cruiser to start before they salt the roads here. |
Ok couple of things and these you can simply read it as a thought.....
Many old ,been around for years fuel stabilizers don't work well with the current formals available in the USA. I recommend to all my customers and friends DO NOT USE THEM. You may find the gas turning to something that resembles the 1958 movie starring Steve McQueen "The Blob". I recommend to add marvel mystery oil to the fuel run the engine until it just starts to smoke a little and shut it down. The oil property will coat the complete fuel supply system and protect it during a season or more storage. At the end of the storage period you simply start the engine go fill the tank and drive. The smoke will be light and will cease after about a second fill up. All the time the the Marvel Mystery oil in the fuel will be cleaning the fuel system and also the combustion chambers of the engine. If you don't invest in a battery charger cantabile of sustain a fully charged battery and you have not load tested the battery prior the storage of the vehicle I recommend simply disconnect it during the vehicles none use. Any other way and you are simply looking for possible poor outcomes! Fabric softeners are a nice idea but what may work a little better and made for the job........# see attached picture. Several forum members have gotten these in various mailings and packages sent to them. ![]() Lastly a car cover is just a logical must. ![]() ![]()
To view larger pictures simply "click " on the picture! Dalai Lama "Share you knowledge. It's the best way to achieve immortality." ASE MASTER TECHNICIAN ![]() ![]() Last edited by NitroPT; 10 Dec 2015 at 11:31 am. |
Thread Tools | |
Display Modes | |
Winter storage...what to do? | Lakota | General PT Cruiser Discussions | 10 | 14 Dec 2014 11:11 pm |
Winterizing the PT? The Cold Has Arrived! | Handy_Cruiser | General PT Cruiser Discussions | 2 | 25 Nov 2013 11:16 am |
Underseat Storage? | buhbuhbuhbecca | Interior Accessories Forum | 5 | 02 Jan 2013 09:57 pm |
Winterizing Agent / Anti-Gel for Diesel Fuel Only | johnbukul | Vendors & Buyers Forum | 1 | 10 Jun 2012 06:39 am |
Under Seat STORAGE BIN | 2003DC2 | Interior Accessories Forum | 2 | 22 Dec 2009 09:51 pm |
