Electrical Problem
  • 1 Post By ptcruisersteve
Old 18 Oct 2015, 06:55 pm
Default Electrical Problem
I recently bought a 2001 touring edition and noticed a few things while driving. First the radio rarely lights up but still works and second the doors will randomly lock and unlock whenever they please. I don't know if I need a new door lock switch and a new radio or what. Any help is appreciated. Thank you.
Old 18 Oct 2015, 07:10 pm
Default Re: Electrical Problem
I would suggest you check the RKEM. The links below will help you in diagnosing your problem with the locking and unlocking issue.
The equipment that controls the doors is called the RKEM (Remote Keyless Entry Module) and is located in the center console above the air vents.
door locks locking/unlocking on their own!
Power locks locking/unlocking while driving?
FYI how I diagnosed and repaired dysfunctioning lift gate remote release
Old 23 Oct 2015, 08:50 pm
Do you have to get the rkem re programmed? Ive read somewhere that if you buy one with key fobs they're all programmed.
Old 23 Oct 2015, 09:43 pm
Transmitters can be programmed to the system by using the follow procedure:
1. Insert the key into the ignition switch and turn the switch to the ON position.
2. Press and hold the Unlock button on the transmitter between four and ten seconds.
3. Continue to hold the unlock button and press the Panic button. A chime will sound to indicate that the transmitter programming mode has been entered.
4. Press a button on all transmitters to be programmed to the system, including any previously programmed transmitters. A chime will sound when each transmitter has been programmed.
5. Turn the ignition switch off to exit the transmitter programming mode."
JoeX likes this.
Old 24 Oct 2015, 09:30 am
If you buy one new or used with out fobs you will need to have programed. If you get one with at least one fob you can program more fobs yourself like above post. no dealer needed.
big electrical problem. Melition Turbo Performance 5 03 Dec 2013 06:44 pm
Help me - Electrical problem!!! Chromenut General PT Cruiser Discussions 11 02 Jul 2013 08:32 pm
REALLY big problem-electrical pluminator General PT Cruiser Discussions 4 27 Jul 2012 04:51 pm
electrical problem. burning electrical plug cruiserjim269 General PT Cruiser Discussions 17 03 Dec 2010 03:38 pm
