Who Does Body Work?
Old 22 Oct 2015, 08:00 am
Default Who Does Body Work?
Okay Guys, I need a little assistance. I got the drivers side front door mounted and am having a little trouble with the way it fits. It closes and latches, but I have to kind of slam it in order for it to latch. Anyone have any tips on tweaking it just a little to make it fit right? I'm thinking if I just loosen the door hinges a little bit and then close it, that may give me the proper angle? I don't know, I'm just speculating. The door lock was a royal pain in the butt to change out. You have to remove one of the window tracks in order to be able to get your hand inside the door to remove the keeper on the back side of the lock. Blind feel, as you can't get a light in there to see what you're doing. I'm just happy that the back door doesn't have a lock cylinder too!
Old 22 Oct 2015, 08:27 pm
Default Re: Who Does Body Work?
Ok, what happened to your old doors? Did you use your hinges or ones on the other doors? Look at the body lines to de if they line up. Squat down and open the door and see if the door is hitting the striker center of the latch. If to high or low. Door won't close well. You will want to get close to the body ad look down the side to see if doors are flush with surrounding panels and each other. Fix the height first. The you can the up and down at the latch worked out. You only need to snug on bolt on each bolt face of the hinge. This make it easer in the adjustment stage. If the have never been moved on one side of the hinge. Make sur you need to mess with it. Might be ok where it is. Just adjust on aspect at a time. Some pics of the pt with the old damage and some looking down the side and were the lines meet the finder and quarter panel. Would be helpful.
Would this welder work on repairs on the body and frame work on pt cruiser? Bandit2014 The Detail Shop 33 11 Apr 2015 08:26 pm
APC Body full body kit for PT listed under San Diego bubba_1952 craigslist 0 09 Oct 2014 07:49 pm
5-speed throttle body work on auto pt? shelbyzman Tech & Performance Forum 2 03 Aug 2013 07:16 am
will this throttle body work on my 04 pt? auction ends in two hours shelbyzman Tech & Performance Forum 5 31 May 2013 10:06 am
ARRRG..Help...anybody know about body work? Cal Cruzer General PT Cruiser Discussions 5 23 Jul 2003 04:18 pm
