Bad oil leak, good dealer
Like Tree8Likes
  • 2 Post By Kayleekitten
  • 1 Post By rckstein
  • 4 Post By Kayleekitten
  • 1 Post By Kayleekitten
Old 28 Oct 2015, 06:12 pm
Kayleekitten's Avatar
Default Bad oil leak, good dealer
Last week my 07 started pissing oil (2qt over night(. I brought it to my dealership on monday, got it right up on the lift and found the leak. It was a worn out front crank shaft seal. They checked for play in the shaft and none, the seal just got worn out. Best case scenario.
While they were at it they replaced all the seals in the front of the engine, all new belts and an oil change.
The cost for all that.........$400. My baby runs so much better now.
Probedude and Gkon like this.
-Kaylee Kitten
'07 PT Cruiser Touring
Old 28 Oct 2015, 07:29 pm
Default Re: Bad oil leak, good dealer
How many miles do you have on it?
Old 28 Oct 2015, 10:48 pm
rckstein's Avatar
Did they put all the old timing belt components back in? Did they replace the camshaft seals as well?
Old 29 Oct 2015, 11:46 am
Keep a watch on your oil. I have never read of this issue without crank walk. Your in the years that were affected. Most don't bother to change them at timing belt change. That's how long these last. Ware doesn't happen overnight. So I'm not convinced your good to go. Do pay attention. Always look for any signs of oil.
Old 03 Nov 2015, 10:47 am
its 76k miles on it. yup they changed all the timing components that could have been effected by oil saturation and replaced they did the crank shaft seal.
The car had a small oil leak when i got it and it got worse as the weather got cool. I am still watching it to make sure it does not happen again.
-Kaylee Kitten
Old 03 Nov 2015, 01:21 pm
rckstein's Avatar
What you paid for your repair seems awful cheap and I don't wish you any bad luck, but I guess I tend to look at things that can go wrong usually do, my pessimistic side of me. You already said they replaced the crank shaft seal as that was the original problem, but your car also has (2) cam shaft seals that can also leak. They were leaking on my PT that last time the dealership had to do the timing belt work. Please look at your receipt, did they replace the: (2) cam shaft seals, timing belt, tensioner, idler pulley and water pump while they had it torn apart? If not, you're not too far from needing to have that work done and, in my opinion, it would have been wise for them to go ahead and do that now rather than tearing it apart again a year from now at another $1000-$1500.
Old 04 Nov 2015, 10:11 am
well the full cost of the repair was about $1000 but they gave a a big break on the cost.
rckstein likes this.
-Kaylee Kitten
Old 04 Nov 2015, 10:14 am
rckstein's Avatar
Sounds like you got a great deal, good dealer, happy PT'ing
Old 04 Nov 2015, 05:39 pm
A BIG break? Man, that's HUGE!!! LOL I'm happy to hear that someone got a break from a stealership. Did you buy it there?
Oil Leak, Vacuum leak Ikster Tech & Performance Forum 1 02 Jan 2013 09:53 pm
dealer sticker logo/dealer license plate cover frances General PT Cruiser Discussions 16 26 Jun 2004 05:57 pm
Looking for good dealer for maintanence! Curruzr Northwest PT Forum 6 06 Jan 2004 04:41 pm
The Dealer Said..... knowyourturbo Turbo Wheels/Suspension/Handling 14 27 Nov 2003 12:12 am
Dealer says no TSB# SFsGT03 General Turbo Discussions 3 20 Nov 2003 08:40 pm
