First thing I would suggest is to have a battery load test done. Make sure you don't have any loose battery cable connections. Some members have found the battery cable connector loose or completely corroded through and came off. Check your battery fluid level.
Do you have many keys on your key ring when you use the key to turn the ignition on? What is the manufactured date on the drivers door of your PT Cruiser? The reason I am asking is to find out if your PT Cruiser has a TIPM.
If at First You Don't Succeed - Try, Try Again Last edited by ptcruisersteve; 29 Oct 2015 at 10:14 pm. |
Hi ptcruisersteve-
I had a similar thought about the battery cable. I recently had the cruise control repaired by the dealer and I wonder if the negative cable is not on tight. Nope no extra keys on the key ring at all. My cruiser was built in Sept of '05. It's an '06 and I believe it does have a TIPM.
![]() ![]() ![]() 2004 Limited Edition Platinum Series, Graphite Metallic, Standard Turbo, automatic, RBQ radio with Sirius Radio & 6 CD changer, VentShades, chrome exhaust tip, door spears, grille inserts, door lock pulls, bright pedals and steering wheel spokes. Red spoiler from a donor PT. Known as: "The RATMOBILE" I bought it Apr 28th, 2016 with 62,400 miles on it. |
What's a TIPM?
I agree with Steve, Wingman. Check those battery cables and connections. I think it's a little too "coincidental" that this has happened after having the cruise worked on. I DO NOT believe in coincidences.
![]() Aspire to inspire before you expire. |
I see, mine looks different and is from 2003 so I guess I don't have TIMP. What good does the TIMP do compared to the old solution?
For the first time ever all exterior and interior lights shut off while driving in the dark a couple months ago. They came back on so fast that I was wondering if I imagined the whole thing. A bit unnerving!!
2004 Turbo Lite Purchased 4 $400 |
ed9msi, there is absolutely NO advantage to having a PT (or anything else) with the TIPM. At least with the 03 model you have, you can trouble shoot various problems that may arise and not have to worry about having to replace a very expensive item. The TIPM controls all of the electrical in those cars equipped with it. Personally, I don't like them. I have a 2013 Chrysler with one and I hope that nothing electrical ever goes wrong with it.
![]() Last edited by rob302; 11 Nov 2016 at 06:23 pm. |
Thread Tools | |
Display Modes | |
Won't crank sometimes - dies when driving - electrical issue? | jmansour | Tech & Performance Forum | 14 | 23 Jun 2014 03:53 pm |
Scary driving in heavy rain and/or standing water. | Cliff5550 | General PT Cruiser Discussions | 13 | 30 May 2013 12:24 am |
Engine cuts out/dies...while driving | ScottS | Tech & Performance Forum | 2 | 13 Mar 2013 07:37 am |
Engine quits while driving | Ornald | Tech & Performance Forum | 2 | 20 Jan 2013 12:55 pm |
engine cuts off while driving | leesa47 | Tech & Performance Forum | 2 | 19 Apr 2012 11:14 am |
