Engine missing at idle
Old 31 Oct 2015, 06:52 pm
rolm's Avatar
Default Engine missing at idle
On my 2008 with only 105k-kms the engine misses at idle or when stopped at the lights. I looked at a few of the spark-plugs and they seem to be ok. It seems the spark-plugs and the wires are original, Considering the car is 8 years old I guess a wire and spark plug change is in order. It does not appear to be missing when driving
Never Forget Life is what you Make it. This is the most Valued Option we Have in Canada & US
Old 31 Oct 2015, 07:01 pm
Default Re: Engine missing at idle
Engine missing at an idle can be caused by:
1. Leaking vacuum hoses. I would suggest you first check all the vacuum hoses under the hood. Check all the hoses for cracks and leaking at the fittings.
2. Faulty radiator fan.
3. Defective spark plugs and spark plug wires.
4. Low engine compression.
5. Other possible components determined after further diagnosis with visual inspection and scan tool.
If your engine light is on what engine trouble codes are you getting?
Old 31 Oct 2015, 07:08 pm
rolm's Avatar
There is no engine light on, I can always plug in my code reader and see if any codes are stored. Also not it does not appear to be missing when driving
Old 31 Oct 2015, 07:16 pm
You might only have a small vacuum leak. Suggest you check the vacuum hoses first.
Old 31 Oct 2015, 07:26 pm
rolm's Avatar
Good suggestion I never thought to check for vacuum leaks. I will do that tomorrow. Thanks
Old 31 Oct 2015, 07:50 pm
What symptoms do you have that you think it's missing at idle?
______________________________________________
Most misunderstandings in the world could be avoided if people would simply take the time to ask, "What else could this mean?
2001 PT Cruiser LE 5 spd, original owner, no mods, MOOG arms with spherical bushing (ride is now a bit harsher vs OEM)
- 109K replaced timing belt/WP/tensioner/idler/crank&cam seals with same 1st gen design. That was a fun day and half!
- 119K Gates water pump failed after only 10K miles. Replaced with Airtex. This time around it was a 7 hour job.
2001 PT Cruiser LE AT 59K miles. Bought used, newest addition to the family
Old 01 Nov 2015, 08:45 am
rolm's Avatar
I can feel the missing and the tac moves a bit, But only at idle
Missing at idle VegasPTGT Tech & Performance Forum 3 25 Oct 2013 06:49 pm
Rough Idle/Missing Under Load Etc. MattTee Tech & Performance Forum 9 03 Oct 2012 07:51 pm
Need help - Rough idle & sputtering, missing out... eobryant Tech & Performance Forum 6 15 Aug 2010 10:51 pm
Rough idle and missing on deceleration brokenfax Tech & Performance Forum 6 21 May 2010 02:10 pm
