Brakes applying underboost?
Like Tree3Likes
Old 04 Nov 2015, 12:11 pm
Default Brakes applying underboost?
Hey how's it going I have a unusual problem with my 04 dream cruiser turbo 5 speed.
So here is what is happening
The other day it was raining out and I decided to do it burn out and spun through 1st through 3rd gear. I let off and then my brake pedal was slightly stiff and I can feel the brakes were applying with out me touching them and slowly getting worse until I couldn't move cause the brake pedal was stiff as can be and my brakes were fully applied? I let it sit for about 3 hours and I was able to drive it home but on the way back it started to do it again?
I thinking it is the brake boost. I just want some opinions before I replace it. Thanks.
Old 05 Nov 2015, 03:22 pm
Flash619's Avatar
Default Re: Brakes applying underboost?
I assume you checked to make sure no calipers are just stuck?
Old 05 Nov 2015, 03:35 pm
i would ASSUME this is a vaccum issue. check valve, vaccum leak, etc.. a stiff pedal does not mean the brakes are being applied, IMO. it's a 200hp 4 banger. if the brakes were even half applied, the car would not move.
a laser temp gun reading brake temps would verify this.
you should be troubleshooting a hard pedal, nothing more. vacuum leak, failing booster, leaking check valve, etc.
Old 05 Nov 2015, 06:12 pm
It was pretty difficult to get it to move but I destroyed my brakes for sure lol
Old 05 Nov 2015, 06:20 pm
whoooa!
Old 05 Nov 2015, 10:19 pm
Flash619's Avatar
Just a little brake cleaner.
Old 05 Nov 2015, 11:24 pm
I read this thread when it was first posted...tried to respond...tried real hard and then I read the first thread again...naw....
Old 06 Nov 2015, 06:38 am
MJKnight's Avatar
when I read the post...this is all I could think of.....
Busted_PT and NitroPT like this.
Old 06 Nov 2015, 08:56 am
That cracked me up!
NitroPT likes this.
Old 06 Nov 2015, 10:38 am
whats really funny is the cop may have been CREWZIN in pursuit? LOL
Tags
brake applying underboost, brake fully applied, brakes stuck
Applying Protective Vinyl Film soonercruiser The Detail Shop 10 05 May 2014 11:30 am
applying pinstripes Excoastie Exterior Accessories Forum 9 07 Apr 2011 08:50 pm
Applying chrome on the exterior? 21walker General PT Cruiser Discussions 9 30 Mar 2009 10:56 am
Thinking about applying to a detail shop TaylorMade The Detail Shop 9 21 Apr 2005 01:01 pm
