Tie Rod End Question
Old 07 Nov 2015, 01:23 pm
Default Tie Rod End Question
In September I replaced a tie rod end.
The new tie rod end is the greasable kind.
I was under my PT the other day touching up some rust spots when I noticed some grease coming out of the tie rod end.
Is this normal?
I have barely driven it 60 miles since I put the new tie rod end on.
Any input is most appreciated.
Thanks.
Old 07 Nov 2015, 01:39 pm
Default Re: Tie Rod End Question
Normal
Old 07 Nov 2015, 03:20 pm
Originally Posted by Tuggajb View Post
Normal
Wow! First time I have noticed that.
I have not changed too many tie rod ends.
Here the grease seems to be coming out of the sides.
Is that normal too?
Thanks for the answer
Old 07 Nov 2015, 03:35 pm
You did grease it after installing it, right?
At first you'll always have a little grease seeping from under the boot. If you wish, just wipe it off.
Old 07 Nov 2015, 04:17 pm
Thanks for the answer.
Yes I did grease it right after installation.
I will wipe off the excess as you suggest.
I did not realize it would leak out so much.
How often should I re-grease it?
:question:daytime running lights!!!:question: jrs61282 Tech & Performance Forum 10 07 Nov 2010 10:53 pm
Luggage Rack question and trailer hitch question Patrick_Dickey General PT Cruiser Discussions 5 26 Apr 2009 09:19 pm
