Cold start, then stalls
Like Tree5Likes
  • 1 Post By ptcruisersteve
  • 1 Post By JoeX
  • 1 Post By BasicCruiser04
  • 1 Post By wb2kki
Old 13 Nov 2015, 08:56 pm
JHCruiser's Avatar
Default Cold start, then stalls
I have a 01 basic cruiser. On cold mornings the car starts fine but stalls if you don't floor the pedal. Only the first 5-10 seconds. It runs fine after that. Is there a cold start injector of something similar? I don't know how the choke works on fuel injection.
List of recent work
New battery
New plugs
Plug wires looked good
Checked and cleaned pcv valve
Cleaned and oiled K&N air filter
Added fuel injection cleaner to tank, 1 tank ago
Checked vac lines
240000km
Dealer said he changed timing belt- no documentation to back up- probably lied
on the list to do
2001 PT Cruiser 4 door Coupe
Old 13 Nov 2015, 09:35 pm
Default Re: Cold start, then stalls
I would suggest if you don't have any engine trouble codes to check your fuel pressure. Make sure you are getting 57 +/-5 PSI
If your engine light is on post what the codes are.
JHCruiser likes this.
Old 13 Nov 2015, 09:40 pm
You may want to look at / change temperature sensor in front of the AC condenser. It may be sending incorrect temp to PCM.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 13 Nov 2015, 10:55 pm
JHCruiser's Avatar
Thanks for your replies.
I have no engine codes showing.
Steve. I will see if I can buy a fuel pressure gauge and check psi. Why would that only effect cold starts?
Joe. Do you know what the values of the air temp sensor. Or where I can find them.
Old 13 Nov 2015, 11:41 pm
My 04 Cruiser would start rough/almost stall sometimes & hesitate at red light/idle.
I just replaced the fuel injectors last Saturday ($69 on eBay)... along with new plugs & new intake manifold gaskets.
What a difference!!! Maybe new injectors will help you too. I had never my fuel injectors cleaned before, but after 12 years & 168,00 miles, I figured buy new ones. Glad I did.
I've also had all the work done on my car that you have. Good luck. I hope all you need are some new fuel injectors.
Old 14 Nov 2015, 09:53 am
When you floor it it puts the car in flood mode. SO sounds like the car may be flooding which can be a few things. Injectors are one of them.
Pull the plugs and see if one or more are not the same correct color and swap that injector with another and check again. If it moves that is the bad injector. If all are fouled something in the fuel system.
Good luck.
Old 14 Nov 2015, 11:14 am
Four basic things an engine needs is air,compression, spark, and fuel. When you have a problem with your PT Cruiser the first thing you want to do is check the four basic requirements that the engine needs.
Because you have no engine trouble codes showing it indicates a possible fuel issue. There are many possibilities when you are in a cold weather environment that can effect your fuel pressure.
Fuel injected engines are sensitive to fuel pressure. If fuel pressure at the engine fuel rail is even a few pounds less than specifications, the engine may experience hesitation or stalling problems.
If the fuel pressure is good I would suggest you do a fuel volume test. A worn fuel pump can prevent it from running fast enough to generate adequate fuel flow when the engine is cold.
2001 cruiser stalls after start JHCruiser General PT Cruiser Discussions 9 07 Nov 2014 03:38 pm
Upon Cold Start in Cold Weather, Loud Noise?? paulrosenthal Tech & Performance Forum 33 01 Oct 2014 09:55 am
P0340 & P1391 code // cold start & occassionally stalls apalomo01 Tech & Performance Forum 13 28 Jul 2012 08:00 pm
Stalls after start and loss of power jatisme Tech & Performance Forum 2 29 Oct 2011 03:55 pm
'03 Cruiser Stalls, Won't Start bjagd02 General PT Cruiser Discussions 5 22 Feb 2011 06:33 pm
