I'd try another fluid and filter change. It sounds like you may have a filter that's partially clogged. Just make sure you use ATF+4 fluid. NOTHING else.
![]() Aspire to inspire before you expire. |
Check the upper and lower motor mounts. May be torn. Will feel it more if the idle is higher.
![]() ![]() ![]() ![]() 03 Dream stock___________________________ 04 Touring turbo lite stock_________ 02 Touring stock_____________________ The "Three Amigos" __________________________________________________ __________________________________________________ ___________Performance, Body and Service, OEM This Is my project page. http://www.ptcruiserlinks.com/forum/...oject-1-a.html This is a great read from one of our own! Badglas badglas.blogspot.com Last edited by Busted_PT; 14 Nov 2015 at 05:39 pm. |
![]() Quote:
Also another vote to make sure it's ATF+4 and not something else plus an additive to make it ATF+4.
______________________________________________ Most misunderstandings in the world could be avoided if people would simply take the time to ask, "What else could this mean? ______________________________________________ 2001 PT Cruiser LE 5 spd, original owner, no mods, MOOG arms with spherical bushing (ride is now a bit harsher vs OEM) - 109K replaced timing belt/WP/tensioner/idler/crank&cam seals with same 1st gen design. That was a fun day and half! - 119K Gates water pump failed after only 10K miles. Replaced with Airtex. This time around it was a 7 hour job. 2001 PT Cruiser LE AT 59K miles. Bought used, newest addition to the family |
Thanks for the advice. Just to make doubly sure I get the correct ATF-4 I made an appointment with my local Chrysler dealership. I have a coupon so it won't be too costly.
Ask them to look at all of the mounts while they're under the car. Busted_PT has been around them for a while, so he gave you good advice. I'm curious as to how much they'll charge you for the fluid and filter change. Be sure you tell them you don't want it FLUSHED, you want it changed with a new filter. Some places just flush out the old fluid and don't drop the transmission pan and replace the filter. I'd ask to see the old filter too. That way, you can be reasonably sure they actually replaced it. That's your right as a consumer. If they can't produce it, I'd be very wary of what they did.
I don't think there is anything wrong with the transmission. I think you have wore out mounts. That's the slop you feel talking up the slack. Easy enough to see before you spend your money.
I did have the transmission serviced with the new ATF4 and filter. I was told that I was not to have high hopes in that it would not prove to be a "quick" fix. Wrong. It did do the trick. Maybe the filter was getting a little clogged, I don't know, but I do know it does not clunk into DRIVE anymore when cold.
![]() Last edited by thecabinguy; 12 Apr 2016 at 04:43 pm. |
Well, thanks for FINALLY getting back to us and letting us know.
![]() Quote:
![]() Last edited by thecabinguy; 06 Sep 2016 at 02:39 pm. |
Thread Tools | |
Display Modes | |
clunk clunk | durango | Tech & Performance Forum | 11 | 01 Aug 2016 10:26 am |
clunk in reverse | wb2kki | General PT Cruiser Discussions | 6 | 23 Apr 2014 09:00 am |
The Clunk is finally GONE!! | Motorhead | General PT Cruiser Discussions | 2 | 05 Jul 2012 08:22 pm |
New LCA's and still have a clunk... | Jetta02awp | Wheels, Tires, Suspension | 0 | 24 Jul 2010 07:13 pm |
Phantom clunk | beefco | General PT Cruiser Discussions | 4 | 03 Apr 2009 08:00 pm |
