Very Strange Electrical Issue Please Help!
Old 21 Nov 2015, 04:50 pm
Default Very Strange Electrical Issue Please Help!
Hi new member/owner here: 01 PT I have has never had a speck of trouble-new last owner. Yesterday, It started this thing where if you turned the key off it keeps running for like 30 secs, then all the gauge lights come on and it will either start and run like crap or not start at all. I researched a little and found the fan relay is often the cause, so I switched it. unhooked/rehooked battery and ran like a champ. But back to square 1 now that I shut it off. Is bad battery or failing altenator possible? thoug I did drive it about 30 miles today. I could use from experience/insight on this. Thanks
Old 21 Nov 2015, 06:58 pm
Default Re: Very Strange Electrical Issue Please Help!
Sounds to me like you might have a problem with the ignition switch.
Old 21 Nov 2015, 07:23 pm
Handy_Cruiser's Avatar
+1 on the ignition switch.
The ignition switch is on the left side of the steering column opposite the key. It can be removed and replaced without disturbing the key and lock. When removed, check the little white plastic shaft running from the key and make sure it's not broken or twisted.
If i was me, I'd remove the ignition switch, inspect the shaft, then blow it out good where it plugs in. Then I'd reinstall it and see what happens. Might just be that the plug got corroded or loose. My Dodge Ram did something similar due a bad wire in the ignition switch plug.
Old 21 Nov 2015, 07:57 pm
I would suggest that you check the wire harness under the PT Cruiser between the starter and crankshaft sensor to the PCM. The wire harness is put in place with a clip and sometimes on the 2001 & 2002 PT Cruisers the clip breaks and the wire harness drops down to the half shaft or frame rubbing through the harness shorting wires to ground. This will not take long and should be checked before looking at the ignition switch.
Old 21 Nov 2015, 10:35 pm
I will try looking at the harness, then switch if needed. I was trying to beat the cold and dark tonight and noticed that when I hook the battery back up, either the fan relay or asd relay clicks off for like a minute.
strange idle issue dalandon Tech & Performance Forum 8 08 Apr 2015 10:25 am
Strange Electrical problem windsblow Tech & Performance Forum 5 22 Mar 2011 09:11 am
Strange Electrical Problem carlton Tech & Performance Forum 9 08 Feb 2011 10:21 pm
Strange AC issue, please help. Montollio Tech & Performance Forum 6 24 Jun 2008 09:34 pm
need advice on strange electrical problem in Jeep comPuTer General PT Cruiser Discussions 1 07 Jul 2004 07:31 pm
