Horn
  • 1 Post By CREWZIN
Old 21 Nov 2015, 11:13 pm
chevy696969's Avatar
Default Horn
When I hit the horn, nothing happens most of the time, then the horn will honk on its own for the rest of my drive, gets to be annoying as hell (Funny) but annoying. Any suggestions what could be causing it?
Old 21 Nov 2015, 11:55 pm
Handy_Cruiser's Avatar
Default Re: Horn
It's possible that it is in the steering wheel. I've never had this happen in a Mopar vehicle. But it's very common in older GM rides.
If I remember right, the horn switch on the PT is inside the airbag and not serviceable. You could remove the airbag, unhook the horn wire and then ground it to something to see if the horn functions normally. If so, just get another airbag at a salvage yard.
Old 22 Nov 2015, 07:55 am
Default Re: Horn
...except about being non-serviceable. The connection could just be loose or corrosion is stopping it from making good contact.
Handy_Cruiser likes this.
Old 22 Nov 2015, 04:13 pm
Default Re: Horn
You could add a alternate horn, At times I could not find the sweet spot on the horn cover fast enough. Adding a second horn has worked out well on my 002. Also it was easy install and inexpensive, The hardest part was deciding where to install horn button, didn't want o drill. decided to make a small bracket. anyway hope this helps.
Old 22 Nov 2015, 08:30 pm
Default Re: Horn
thanks for the info, looks like I'll be taking apart the steering wheel soon.
05 Horn Goes Off By Itself bethelkid General PT Cruiser Discussions 2 30 Dec 2010 11:11 am
second horn 4SPEED General PT Cruiser Discussions 8 29 Sep 2006 05:25 am
New Horn Sandy-GRR8PT General PT Cruiser Discussions 11 06 Apr 2006 08:40 am
Horn Jimbo General PT Cruiser Discussions 8 29 Mar 2004 10:40 am
A-uo-Ga Horn turbomangt General PT Cruiser Discussions 14 06 Feb 2003 10:01 am
