Problem with driver side window
  • 1 Post By evonna_21
Old 27 Nov 2015, 01:54 am
Default Problem with driver side window
I just purchased a 2006 base model pt cruiser. All windows worked when I bought it the other day. Now all of a sudden, the driver's side window doesn't work. Any help would be appreciated. Not sure what's wrong with the window and why it would all of a sudden stop working and all the rest of the windows work perfectly.
Also, yesterday a battery light came on while I was driving it. It just stayed on.
Old 27 Nov 2015, 04:58 am
LionPT's Avatar
Default Re: Problem with driver side window
Bad battery connections can give all sorts of problems...
Check your battery connections along with these 2 ground connects behind the air box.
Old 27 Nov 2015, 09:03 am
Check your switch too. If you're getting power to it, then you can probably open the switch and clean the contacts. Sometimes it's the simple things that we overlook.
Old 28 Nov 2015, 10:51 pm
Thank you for responding. I have to sound clueless but how do I find out if the switch is getting power to it. Do I need to get a machine.
Old 29 Nov 2015, 06:41 am
You need a test light. Turn the ignition switch to the start position, but don't crank it. Probe the wires in the switch and see if the light comes on. If it comes on, you have power, if not, then check for a broken wire or blown fuse. If those are okay, then it's most likely the switch. If you don't know how to use a test light, you need to take it to someone that does know.
Old 19 Dec 2015, 02:06 pm
I took it to a mechanic and he said I needed a window regulator. Problem solved.
Driver Side Window Problems...ANNOYING Cathy06PT PT Cruiser Convertible Forum 10 01 Apr 2018 08:42 pm
HELP! DRIVER'S SIDE WINDOW WON'T GO UP golddust General PT Cruiser Discussions 9 30 Mar 2017 08:05 am
Front Driver Side Power Window Stopped Working itsjusme Tech & Performance Forum 4 08 Dec 2014 01:24 pm
06 -10 PT CRUISER DRIVER SIDE PLASTIC WINDOW POST COVER TRIM chiefsfanforever70 Classifieds: Want To Buy 0 05 Jul 2014 11:02 am
Driver Side Door Lock Problem mstyler05 Tech & Performance Forum 2 20 Dec 2010 10:10 pm
