Lights not working
Old 01 Dec 2015, 10:22 pm
Default Lights not working
I have a 2006 PT Cruiser base model. When I try and turn on the exterior lights nothing happens (no lights). Running or headlights they don't come on. The headlights do come on when i lock the car with the fob. I pulled and checked all the fuses since none seem to be labeled as headlights or exterior lights. What should I check next?
Thanks.
Old 01 Dec 2015, 10:27 pm
rckstein's Avatar
Default Re: Lights not working
Thanks.
My PT did a similar thing. I would try disconnecting the battery to reset the TIPM. While the battery is disconnected, clean the terminals, also check the ground wires behind the battery on the inside of the fender that they are clean. There is also a smaller wire connected to the positive terminal end. Disconnect it and clean under it, as well. Leave the battery disconnected for about 15 minutes and reconnect. This was all I did to my PT over a year ago now and all has been fine since, didn't have to replace anything. Good luck.
Head Lights and Tail lights not working. 1morgana General PT Cruiser Discussions 6 15 Nov 2014 12:38 am
TAIL LIGHTS ND BRAKE LIGHTS NOT WORKING mccloud12 Tech & Performance Forum 7 12 Jun 2014 06:21 pm
Fog lights not working Autoglass General PT Cruiser Discussions 5 20 Apr 2010 10:05 am
Fog lights not working SRT8guy General PT Cruiser Discussions 11 14 Apr 2009 08:13 am
