2001 PT Ltd 145,000 miles
Old 10 Dec 2015, 12:54 pm
Default 2001 PT Ltd 145,000 miles
I recently had all the belts replaced in the engine...some were originals. Had the regular maintenance oil and fluid change done also. Since then when the temp has dropped below 45 degrees,more to the point below 40.....when I start and put in gear (automatic) there is this whinning, scraping sound as I start to move. It sounds metallic and gets higher pitched the more I accelerate. However, the more I drive the higher pitch it gets and then eventually within 5 minutes the sound is gone and does not happen again until the car has been parked. At least parked overnight and the temps drop, sometimes for a few days. I had the timing belt changed about 3 - 4 yrs ago. Any ideas on this? As stated, it only happens when it has sat for a day or so in cold temps below 40. Thanks
Old 10 Dec 2015, 03:28 pm
Default Re: 2001 PT Ltd 145,000 miles
Get yourself a piece of heater hose and a funnel and carefully check each pulley with the engine running. I suspect you have a bearing going out in one of them. But, it could be any one of them. I'd start with the alternator, a/c clutch and belt idlers. I don't much think it's water pump or power steering, but you should check them too. The hose goes near the pulley and the funnel is for you to listen. Of course, some people do this with a long screwdriver or a mechanics stethoscope, if they have one.
Parting out my 2001 PT. (17,000 miles) Rstockum Classifieds: For Sale/Trade 17 25 Sep 2015 02:24 pm
2001 with 4,000 Miles on it? lellis General PT Cruiser Discussions 16 29 Jun 2015 11:16 pm
New Guy -- 2001 PT Cruiser, 123K miles tcarlisle Tech & Performance Forum 4 29 Jul 2012 08:13 am
Surging Problem 2001 PT 13k miles thebearII Tech & Performance Forum 13 30 Aug 2010 05:39 am
2001 Limited for sale 3k miles! 2ptornot2pt Classifieds: For Sale/Trade 0 17 Nov 2004 08:37 pm
