Getting harder to start PT
  • 1 Post By chuzz
Old 12 Dec 2015, 07:52 am
Default Getting harder to start PT
This summer, I noticed the engine didn't start right up the way it always had. It would turn a bit, stop, then turn some more and fire up.
Tested the battery; it was fine.
As the temperatures began dropping, the engine would take longer to start. It would turn & stop, turn & stop. The stops got longer. When it's around freezing, I've been crossing my fingers.
It seems to run fine once it starts, although this morning it seemed to want to stall out shortly after starting.
Would you suspect clogged fuel lines or bad fuel pump, or something more electrical?
Old 12 Dec 2015, 08:12 am
Default Re: Getting harder to start PT
Clean your battery ground connections. Especially the ones behind the battery, mounted on the fender well. If that doesn't do it, you probably just need a new starter.
LionPT likes this.
Old 12 Dec 2015, 11:47 am
I would suggest having a battery load test done after checking the battery cable contacts. Make sure you do the battery load test with the battery in the PT Cruiser so you will know if the generator is charging the battery properly.
If the generator is charging the battery properly I would check the fuel pressure. Make sure the pressure is 58 +/-5 PSI.
Old 13 Dec 2015, 09:00 am
One shop is telling me that it's the computer (ECU/PCM/ECM?) incorrectly controlling fuel flow, turning fuel off and on during a start?
Old 13 Dec 2015, 10:56 am
That's probably the last thing you want to do after all the other checks that was suggested above. Also, you didn't fill in your profile to say where you are. Anywhere where it's starting to get really cold overnight? Might have some condensation in the fuel tank. Gas line anti-freeze or any of the other additives that get rid of water might help.
Old 13 Dec 2015, 01:19 pm
Indiana
I will get something to remove any possible condensation this afternoon. Thanks!
Shift linkage cable bushing replaced again now shifting harder CruiserLady Tech & Performance Forum 14 11 Aug 2012 12:41 am
harder to shift automatic tron101 Tech & Performance Forum 5 29 Dec 2010 05:29 pm
DO YOU THINK INTERSTATE DRIVING IS HARDER OF A CAR THEN STOP N GO TRAFFIC? Tazorac General PT Cruiser Discussions 5 29 Jun 2010 06:18 pm
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
Harder bumps after changing from 205/50 to 225/45? Jeff V Wheels, Tires, Suspension 8 15 Apr 2005 10:53 am
