I would suggest verifying that Fuse #1 is good for the head lights.
If there is no power to fuse #1 on both sides check fuse #10 in the Power Distribution Center (PDC). If the fuse #10 is ok check for open in Red/White wire from the PDC to the fuse block or connection in C106. Does the power locks work?
If at First You Don't Succeed - Try, Try Again |
You have the Limited Edition so your should have fog lights. Are they working? Have you ever had problems with the MFS?
Rules of the forum have been updated as of *07/07/2019* Please read them over. - All decisions by the Moderator are semi-permanent, can and may be changed at his discretion but definitely will be the final word. Any action performed by the Administrator or Moderators are not to be discussed on the forum. |
Yup, the Remote Keyless entry System still works fine. I addressed that last fall.
When you mentioned the the PDC, is that the fuse bank I referred to in the beginning thread or some place else I should check. Looks like I'll have to break the continuity tester out after a couple a beers and the Panthers game. "Go Panthers". If there is a common denominator, Ccould it be a relay? Advise. Thanks. Happy PTin', ptprice
SOOO BIG ![]() ![]() Cool Vanilla White, 3 Coats. 2.4 DOHC 16V SMPI Eng. Vanity Cover, 4 Spd. Auto Trans. 2.6 Overall Top Gear, Lock-up Torque Converter. PT Chrome Clad 16" X 6" Wheels, P205/55 R16 Cooper Starfire/Solarus tires, Touring Suspension. Chrome Package; Side Spears, Grills, Fuel Filler Door, Door Locks, Handles, PRND3-1 Bezel, Silver/Chrome Shift Ball/Knob, Bright Spoke Leather Tilt Steering Wheel. Chrome Tail Lights, 3/8" Belt Trim. Cruise Control, Power Mirrors, A/C, Deep Tinted Sun Screen Glass, Power Moon Roof, Fog and Back-Up Lights, Rear Spoiler, Variable Front Wipers W/Washers, Rear Wiper/Washer, Key less Entry, Replacement 2001 Dark Taupe Grey Suede/Leather Trim Seats, Dual Under Seat Storage Drawers, Drivers Side Power Seat Height Adjust. Full Length Console, Locking Glove Box, Overhead Temperature/Compass Console, Rear Shelf Panel, AM/FM CD GPS Navigation Radio, 6 Premium Speakers, Back up Camera/ 7" Monitor. |
The PDC (Power Distribution Center) is the black box with fuses and relays in the engine compartment.
The power distribution center is under the hood behind the battery. You will have better access to it if you move the air filter out of the way.
I'll delve into that. Somethin' to futz with. Hope I can get 'em working.
Thanks. Happy Ptin', ptprice
I was just down in Ormond Beach for the Turkey Run.
I would check the voltage at the lights and be sure to use the ground to the light when you check it. Then check the ground to the stud on the left fender which holds several ground cables and one larger one to the battery. Pull the bulb out and check filament too. You may have to take out the PDC to check for burned wires. Did you use the same watt bulbs or did you go higher the oem?
Addicted to Mopar You can tell how old I am.. 65 Dodge Coronet 6 cyl 2dr Post 66 Ply Satellite with 273 engine swap to 69 340 4spd 70 340 4spd Dart Swinger "Those were the days my friend" 73 Charger SE Had a few Vetts on the way 69, 85 Several Neons some flips 01 Sebring flip Cruiser's 01, 220K Gone to a new home Cruiser 03 133K Gone to a new home Cruiser 06 110K Project Gone to new Home Cruiser 05 Ltd 120,809 bought with broken belt Oct2015 May 16 Resurrected to once again roam the streets. 20 Miles South Of Pittsburgh Last edited by JoeX; 13 Dec 2015 at 08:06 pm. |
Crewzin, When I referred to driving lights my terminology may have been wrong. Indeed these are SOOO BIG's fog lights.
The MFS has never had a function challenge and has always worked in every respect including activation of the Fog Lights when pulled out. I realize that function is overridden when the high beams are on. The conundrum is the coincidence of both fog lights and both high beam lights dysfunctioning together. I'm sure there's a clue in there I'm not seeing. I'll futz with it tomorrow. "Let there be light!" ![]() Thanks for the input to date, keep them ideas comin' in. With that help, I'll figger it out. Happy PTin', ptprice
I've crawled all around SOOO BIG's neither regions today to estabilish what gives with the dysfunctioning high beam and fog lights. I've not had success yet but have determined the following;
All bulbs in question test good with a continuity check, all fuses have been checked visually and with a continuity tester. This included the fuses in the fuse assembly on the dash and the appropriate suggested fuses in the Power Distribution Center. I'd found that the cover plate on the PDC hadn't been secured properly so each fuse was not only checked but cleaned pursuant to the possibility of water or humidity infiltration on the connections. Additionally I checked for 12V power to each of the bulb plugs when the Multi function switch was in its proper position. There was no voltage read. This may point to a dysfunction in the MFS. I've personally never had the MFS off but the steering column was dropped during the A/C work last year. Perhaps a connection to the switch wasn't replaced or improperly fitted. I do have recollect that when my son Steve and I drove SOOO BIG to the Gator Nationals in Northern Florida last year he instructed me on how the MFS worked. I hadn't been aware. At that time everything functioned. Low beam, fog lights and high beam. Am I possibly missing a ground wire that's common to both sets of bulbs that wasn't reconnected during reassembly? I hope my follow through today can bring illumination to this dysfunction. Please advise. Thanks. Happy Ptin', ptprice
SOOO BIG ![]() ![]() Cool Vanilla White, 3 Coats. 2.4 DOHC 16V SMPI Eng. Vanity Cover, 4 Spd. Auto Trans. 2.6 Overall Top Gear, Lock-up Torque Converter. PT Chrome Clad 16" X 6" Wheels, P205/55 R16 Cooper Starfire/Solarus tires, Touring Suspension. Chrome Package; Side Spears, Grills, Fuel Filler Door, Door Locks, Handles, PRND3-1 Bezel, Silver/Chrome Shift Ball/Knob, Bright Spoke Leather Tilt Steering Wheel. Chrome Tail Lights, 3/8" Belt Trim. Cruise Control, Power Mirrors, A/C, Deep Tinted Sun Screen Glass, Power Moon Roof, Fog and Back-Up Lights, Rear Spoiler, Variable Front Wipers W/Washers, Rear Wiper/Washer, Key less Entry, Replacement 2001 Dark Taupe Grey Suede/Leather Trim Seats, Dual Under Seat Storage Drawers, Drivers Side Power Seat Height Adjust. Full Length Console, Locking Glove Box, Overhead Temperature/Compass Console, Rear Shelf Panel, AM/FM CD GPS Navigation Radio, 6 Premium Speakers, Back up Camera/ 7" Monitor. Last edited by ptprice; 15 Dec 2015 at 01:12 am. Reason: late night syntax correction |
Thread Tools | |
Display Modes | |
Looking for some quick advise. | pianomanc328 | Turbo Performance | 13 | 06 Feb 2015 07:21 pm |
FYI how I diagnosed and repaired dysfunctioning lift gate remote release | ptprice | Tech & Performance Forum | 0 | 27 Dec 2014 08:31 pm |
NEED HELP,WISDOM, ADVISE PLEASE | MURPHYJ | General PT Cruiser Discussions | 5 | 09 Dec 2014 04:51 pm |
Injector advise | Kevhead | Tech & Performance Forum | 0 | 03 Feb 2012 10:41 pm |
To keep or not to keep. Need advise. | jazzbot | General PT Cruiser Discussions | 22 | 11 Nov 2011 12:20 am |
