2006 Limited TIPM
Old 14 Dec 2015, 11:44 am
LM3 LM3 is offline
Default 2006 Limited TIPM
Is there a way for me to view and clear TIPM codes?
Old 14 Dec 2015, 12:52 pm
Default Re: 2006 Limited TIPM
Try this to view the codes....
How to retrieve fault codes.
To clear them properly you need a OBDII/scanner. To temporarily get rid of them, disconnect the negative battery cable for 5 minutes.
Old 14 Dec 2015, 03:57 pm
Are you asking TIPM specific trouble codes or generalized engine trouble codes?
Old 14 Dec 2015, 04:09 pm
LM3 LM3 is offline
TIPM. I have an OBD II code reader. Will that show the? I just paid to have the codes cleared so the drivers side low beam would work. If it happens again I would like to clear the problem myself.
Old 14 Dec 2015, 05:02 pm
From what I understand you could use the StarSCAN to read the TIPM fault codes. Also the TIPM can only be reset a certain number of times. Make sure you verify this scan tool will work on your PT Cruiser.
Below is a link to an aftermarket type StarSCAN.
Chrysler-Star Scan, Application:Chrysler/ 300c, Chrysler/ Pt Cruiser, Chrysler/ Grand Voager, Chrysler/ Sebring
Old 14 Dec 2015, 10:11 pm
767skyking's Avatar
Snap-on Solus!
The "Three Amigos" (And Growing)
Performace, Body and Service, OEM
"Team Amigos FREE Parts!! PM me for details!!
2006 PT Cruiser Help! (TIPM? WCM?) JThomp General PT Cruiser Discussions 48 17 Jun 2017 07:40 am
TIPM ISSUE - 2006 PT CRUISER TOURING jedi385 General PT Cruiser Discussions 3 13 Aug 2015 11:40 am
Integrated Power Module (TIPM) 2006 PT Touring Edition 4dr, 2.4L OldCorps Tech & Performance Forum 11 14 Oct 2014 05:11 pm
Which Key Fob for 2006 Limited adjuster Sound and Security Forum 0 14 May 2013 10:29 pm
2006 PT Cruiser Limited please help ptcruiser2006limited General PT Cruiser Discussions 8 14 Oct 2010 07:18 pm
