Heater & Ac not working right
Old 15 Dec 2015, 03:17 pm
Default Heater & Ac not working right
I have a 2008 PT Cruiser. Purchased couple years ago after being repaired from hitting a deer. In Summer after about 45 minutes highway driving the AC freezes up and won't work. In the winter after about 45 minutes of highway driving the heater stops circulating and it is cold in the car. Both times you can hear the blower trying to work and feel slight air coming from vents. (hot from heater and cold from AC) This makes this car not a very good highway car. I have had the AC recharged and all fans on motor are running. Where should I look on the inside of the car. Thanks mark
Old 15 Dec 2015, 03:54 pm
Default Re: Heater & Ac not working right
Flush the heater core and see if your heat improves. The a/c sounds like you have a line that got partially crushed from the deer. Now, I'm not a mechanic, so don't take my word for any of this. I'm just a speculator.
Old 15 Dec 2015, 08:22 pm
You said both times the blower motor sounds like it's trying to work. Maybe the blower motor is shot. As you mentioned, it has heat, just not blowing into the cabin very well. Same goes with the air conditioning.
Just something to consider. Found a youtube on how to either replace or check to see if it's functioning properly:
http://www.bing.com/videos/search?q=...ED3&FORM=VIRE1
2016 Kia Soul Plus Black
Old 16 Dec 2015, 11:12 am
Thanks. I will try both.
Old 28 Jan 2016, 09:09 pm
flushed heater core and checked lines. Changes the blower motor and still after approximately 45 minutes of working fine the heater air starts to decrease. The temperature heat is still hot but much less air flow. sounds like motor is running fine and you can hear the speed setting change just no air flow. Is there some kind of vent flap or something that regulates the air flow? Thanks Mark
Old 28 Jan 2016, 09:21 pm
LionPT's Avatar
This is just a guess...have you checked the fresh air vent behind the windshield washer fill tank..??
You will have to remove the cowl to access to check if it's clogged or blocked.
Even if you don't have the cabin filter box, the hole is still there & open.
Old 29 Jan 2016, 06:37 am
When my A/C froze up (twice), both times it turned out to be the low pressure switch on top of the accumulator. Easy to replace as you don't loose the R134 when you replace the switch. You just have to watch out for the tiny "O" ring on the threads as you can over-tighten it when screwing down the new switch.
Heater Mode Selection Not Working essendy General PT Cruiser Discussions 1 14 Jan 2016 12:06 pm
AC/Heater Blower Not Working Nick Tech & Performance Forum 3 19 Dec 2014 11:32 pm
05 Touring turn signals working & not working angel66rose Tech & Performance Forum 5 11 Dec 2013 09:34 am
02 Blazers heater not working kenlesher Tech & Performance Forum 3 29 Nov 2009 01:48 pm
Block Heater, Rad Hose Heater, Which?? kb0nly Tech & Performance Forum 13 23 Dec 2008 03:47 pm
