rear brake noise
Old 19 Dec 2015, 11:44 am
Unhappy rear brake noise
Yesterday the right rear started a grinding scraping noise with an occasional bang like you dropped something on the rear floor on my 2001 PT limited, the car has rear disc brakes and looking at it on the lift there was a big hole where the parking brake spring retainer was. Apparently the hole opened up due to rust and corrosion and the brake pieces came loose in the drum. This car only has 54000 miles but we live in New England. The Chrysler dealer will only sell the complete brake assy. for $300 each side and looking at the left side it won't be long for that one too. Considering the labor involved would it just be better to replace the whole rear axle with a good used one for $400 or rebuild what there is in the brake. Everything worked perfectly until yesterday and the big bang. Your comments would be appreciated.
Old 19 Dec 2015, 12:57 pm
Default Re: rear brake noise
IF you need to drive it until you get parts, at least take it apart and remove the broken pieces inside the parking brake. It may lock up if you don't.
I've seen Neons where the bonded lining come loose and jams the wheel from turning.
It always happen when it freezing.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 20 Dec 2015, 07:51 am
^ x2 on the neon shoe bonding failing. do you not have any pick-apart-yards near you? both entire rear brake assemblies should be dirt cheap if you could pull them yourself. of course, you could just gut the e-brake components from the junked side and keep driving it if youre in a pinch. do you use your e-brake often?
if not.....
Old 20 Dec 2015, 08:25 am
SR thanks, I use the parking brake every time.Car is in the shop now waiting for the replacement axle beam from a wreck. Mechanic thought that's the best approach, less labor and half the price of new brake assemblies. We'll see next week and let you know. The car looks great and has low miles (54000) as I only use it once a week but New England winters have taken their toll even being garaged. Last month I had to replace both front strut/spring assys. as I broke a spring in one and also lost a tie rod. Being retired and on Social Security us old folk can't afford a new car so we'll keep this one going for awhile. Merry Christmas, Barry
To follow up : We junked the used axle beam idea (bad shape)and bought new backing plate kit assemblies from Chrysler. The parts that were not needed were sent back to the dealer for refund. Pretty good deal as the total job ran just over $700. I don't know if he replaced the parking drums, the old ones may have been fine.
Seeking Help W/ Diagnosing Rear Brake Noise jiblition Wheels, Tires, Suspension 6 14 Jun 2015 05:09 pm
Brake noise... ?? theKING General PT Cruiser Discussions 16 15 Feb 2015 09:55 pm
clicking noise from rear brake revisited rotty Tech & Performance Forum 1 21 Mar 2014 01:41 am
Brake like noise phxazkid General PT Cruiser Discussions 1 09 Nov 2013 07:47 pm
Rear brake noise... Striker Wheels, Tires, Suspension 4 04 Jun 2006 12:01 pm
