Do any of you guys know how to adjust the headlights on the PT? Mine are too low and I need to raise them. I THINK I can figure it out if I just study them, but I'm a pretty lazy person and just hope someone here can explain it to me!
![]() Aspire to inspire before you expire. |
Three things to look at are
are the lens clear-- polishing lens if you cannot see the bulb helps immensely although its a short time fix, polish again and again. Are there the same size tires on the rear of vehicle as front? Adjustment is the vertical rod , I think its a reverse torx, but here in the north they are so rusted you cannot turn them. But if your lucky enough and yours do turn do it one turn at a time, then test.
Addicted to Mopar You can tell how old I am.. 65 Dodge Coronet 6 cyl 2dr Post 66 Ply Satellite with 273 engine swap to 69 340 4spd 70 340 4spd Dart Swinger "Those were the days my friend" 73 Charger SE Had a few Vetts on the way 69, 85 Several Neons some flips 01 Sebring flip Cruiser's 01, 220K Gone to a new home Cruiser 03 133K Gone to a new home Cruiser 06 110K Project Gone to new Home Cruiser 05 Ltd 120,809 bought with broken belt Oct2015 May 16 Resurrected to once again roam the streets. 20 Miles South Of Pittsburgh |
Thanks to both of you guys. I got the PM, Nitro. But, the reason I THINK they need adjusting is because this car has a salvage title and I do know it took a slight hit to the front end. Reason being is that the radiator support has a slight bow to it and a ding on the bottom and I had to replace the front bumper assembly. It was not in good shape and was pretty obvious that someone had done a half-assed paint job on it too. The color didn't quite match. I'll use my 200 as a guide line for adjustment. I'm going to park it about 25 feet away from my garage door and use some masking tape to mark where the lights on it hit. Then, I'll put the PT in the same spot and see if I can get close. I KNOW they're not the same bulbs as the 200 has much brighter lights, but if I just adjust the PT lights up to close to where the 200's hit, I think it'll be okay. I appreciate the information.
Okay, I found the adjuster screws and managed to get the driver side headlight picked up and adjusted fairly well. The passenger side is being a pain, though. I know the screw is turning, but the headlight isn't moving. And the odd thing is that the headlight shines out better on low beam than on high beam. High beam hits the road about ten feet in front of the car. Is it possible that the bulbs are in the wrong sockets? I've never replaced them, but that doesn't mean a previous owner didn't screw them up.
![]() Aspire to inspire before you expire. Last edited by chuzz; 20 Dec 2015 at 07:56 pm. |
The headlight adjuster may be stripped from impact if it doesn't move with the adjusting screw.
It is possible that the bulb is not inserted correctly into the housing. It may be evident by comparing the left and right bulbs through the lens. Bulb will be angled slightly down and when removed it will not take much twisting for it to come out.
Addicted to Mopar You can tell how old I am.. 65 Dodge Coronet 6 cyl 2dr Post 66 Ply Satellite with 273 engine swap to 69 340 4spd 70 340 4spd Dart Swinger "Those were the days my friend" 73 Charger SE Had a few Vetts on the way 69, 85 Several Neons some flips 01 Sebring flip Cruiser's 01, 220K Gone to a new home Cruiser 03 133K Gone to a new home Cruiser 06 110K Project Gone to new Home Cruiser 05 Ltd 120,809 bought with broken belt Oct2015 May 16 Resurrected to once again roam the streets. 20 Miles South Of Pittsburgh Last edited by JoeX; 21 Dec 2015 at 03:00 am. |
Thanks, JoeX. Bulbs are fine, so I'm guessing the dang adjuster is stripped or broken on the passenger side. I MIGHT get into it Tuesday or Wednesday. Just not sure I want to tackle it right now.
Thread Tools | |
Display Modes | |
Is it possible to adjust the camber on PT Cruiser | Bandit2014 | Wheels, Tires, Suspension | 27 | 17 Sep 2015 03:17 pm |
Adjust/Aim '06 Fog Lights?? | CruzinGT | General PT Cruiser Discussions | 3 | 12 Mar 2012 01:16 pm |
Adjust the speedometer? | Calab | Tech & Performance Forum | 3 | 09 Sep 2011 02:15 am |
Ebrake adjust | Semp0560 | General PT Cruiser Discussions | 2 | 15 Aug 2011 12:56 pm |
How To Adjust Idle?? | tcr1016 | Tech & Performance Forum | 5 | 07 Sep 2010 07:45 am |
