P 0462 fuel sender voltage
  • 1 Post By royleroyleroy
Old 20 Dec 2015, 05:30 pm
Default P 0462 fuel sender voltage
Yesterday I replaced my upper/lower torque struts on my 05. The car was
jacked up with the tank almost empty. After starting, the fuel gauge doesn't
work and the code P 0462 (fuel sender voltage too low) came up. I filled the
tank, then disconnected the battery, but the code came back after 30 seconds.
Any suggestions before I take it to the shop?
So much for saving money by doing the struts myself
Old 20 Dec 2015, 06:12 pm
Default Re: P 0462 fuel sender voltage
Because Trump
Old 20 Dec 2015, 08:57 pm
Thanks for the reply - access it from below or above?
Old 25 Jan 2016, 12:59 am
following up, can I access the connector from top or bottom - thanks
Old 25 Jan 2016, 09:41 pm
an update in case someone is looking for this in the future. I apparently
broke a fuel sending unit ground wire, which is attached to the right upper
fender well. I must have damaged it while wrestling the upper strut out.
To the shop it goes, as I'm done messing with this issue
2002 PT (in tank) Fuel Pump/ Fuel Sender cruiserich Classifieds: For Sale/Trade 0 27 Jan 2009 06:08 pm
Error Code Fuel Level Sender arizonasportsnstuff Tech & Performance Forum 2 26 Feb 2008 07:10 am
P0452 Fuel Tank Pressure Sensor Circuit Low Voltage dornstar General PT Cruiser Discussions 0 22 Aug 2007 12:05 am
P 0462 zzzhuh General PT Cruiser Discussions 4 13 Sep 2004 06:19 pm
Fuel Pressure Sender PeTe Turbo Performance 3 01 May 2003 02:26 am
