I just swapped the coil to fix my cyl 4 misfire. I got a coil from the local pick n pull and after i swapped it i went to start her up and it idled high and uneven. Found out i put the rad hose clip in between the intakes rather than above them. Fixed that now it starts and dies unless i give it gas. It sounds great and doesn't havr the miss now but it won't stay running.. any ideas?
Yes it has the p0304 because i didn't clear it yet but none other than that. Through searching the web and forum I was going to try the idle air control valve and then the throttle position sensor... Would you say that's a good game plan?
Do you have an all-data subscription ? ALLDATAdiy.com Leading Source of Factory Automotive Repair Information
I would clear the code first and also reset the battery and see if it comes up again after a few start/warm up and drive cycles. According to the troubleshooting guide for your code, the ignition coil is not the only thing that could have failed. When troubleshooting you have to be 100% sure it's that one item before changing it. POSSIBLE CAUSES Intermittent misfire Visual and physical inspection Ignition wire ASD relay output circuit (coil) Engine mechanical problem Ignition coil Coil control circuit Spark plug Checking fuel pressure Fuel pump inlet strainer plugged Restricted fuel supply line Fuel pump module Checking fuel leak down Fuel injector operation ASD relay output circuit (injector) Fuel injector Injector control circuit PCM (ignition system) PCM
2003 GT M/T in Onyx Green Pearl on Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17. Dark Slate Gray Interior. OEM cargo net, parcel shelf, slush mats and trunk protector, mud flaps, mopar subwoofer. Platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover. Generic lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit. Urethane insert engine mounts. Energy suspension full body urethane bushing kit. Chrysler premium front speakers, Jenson 6x9 rears. Boston Audio 4x55W amp. Panasonic head unit with xtenzi bluetooth. 300W AC power inverter. Escort 360max and Escort Shifter ZR4, dual front+rear dash camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Needswings 3" exhaust elbow, Electric valve actuated Y-pipe with catalytic converter. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter |
I am suggesting you might have an vacuum leak. Check the vacuum hoses such as the PCV valve to the manifold, throttle body,etc. Check the intake manifold for vacuum leaks.
Reset the DTC's and check to see if any other codes come up.
If at First You Don't Succeed - Try, Try Again |
Thread Tools | |
Display Modes | |
car won't stay warm | gresal79 | Northeast PT Forum | 18 | 12 Nov 2014 09:45 am |
WIRING FAN TO STAY ON? | olabaha | General PT Cruiser Discussions | 2 | 10 Jul 2010 07:34 pm |
03 GT Cruiser wont stay running. | 03GTCruiser | Tech & Performance Forum | 2 | 23 Feb 2010 12:14 am |
liftgate won't stay up | prettybluewoody | General PT Cruiser Discussions | 10 | 07 Apr 2008 11:26 pm |
