My daughter's '08 has 95.5K miles. Was thinking ahead since Chrysler recommends replacement at 102K, so I called the dealer.
To say that I am absolutely stupefied at this, for a recommended maintenance item, is the understatement of the millenium. I have two Chevy Cobalts that have no timing belt. Dealer recommended replacement of alternator belt and serpentine belt while they were in there. Those are included in the $1,600 price. Opinions? Thank you. |
What makes the timing belt so expensive to change ? Does the engine have to be dropped ?
2003 GT M/T in Onyx Green Pearl on Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17. Dark Slate Gray Interior. OEM cargo net, parcel shelf, slush mats and trunk protector, mud flaps, mopar subwoofer. Platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover. Generic lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit. Urethane insert engine mounts. Energy suspension full body urethane bushing kit. Chrysler premium front speakers, Jenson 6x9 rears. Boston Audio 4x55W amp. Panasonic head unit with xtenzi bluetooth. 300W AC power inverter. Escort 360max and Escort Shifter ZR4, dual front+rear dash camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Needswings 3" exhaust elbow, Electric valve actuated Y-pipe with catalytic converter. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter |
Find you a good indepent shop that has worked on PTs before they will be around $800-$1200 make sure you do the timing belt water pump and tensioner Like Handy Said the parts are around $300 for all of them its the labor
The most important thing is get a GOOD WARENTY one that says if its not right they will redo it if it is 1 tooth off it will not run right and its just as hard to do it the second time as the first and most shops will try to ge around it sorry its just part of owning a really cool car---they say a BMW is even more expensive |
Dealer parts are around $400 and labor is about $100 hr.
Addicted to Mopar You can tell how old I am.. 65 Dodge Coronet 6 cyl 2dr Post 66 Ply Satellite with 273 engine swap to 69 340 4spd 70 340 4spd Dart Swinger "Those were the days my friend" 73 Charger SE Had a few Vetts on the way 69, 85 Several Neons some flips 01 Sebring flip Cruiser's 01, 220K Gone to a new home Cruiser 03 133K Gone to a new home Cruiser 06 110K Project Gone to new Home Cruiser 05 Ltd 120,809 bought with broken belt Oct2015 May 16 Resurrected to once again roam the streets. 20 Miles South Of Pittsburgh |
That's a little on the high side, but about the going rate from a dealership. What I consider are the things that should be replaced as part of the job are: timing belt, water pump, tensioner, idler pulley, (2) camshaft seals, crankshaft seal, center motor mount. The other belts on the outside of the engine (serpentine and alternator) can always be replaced later, but if they have never been replaced, they are probably due and might as well.
Just pick a shop that you feel comfortable with and offer a warranty. Be cautious about going with someone with little experience as even experienced mechanics have made mistakes on the timing belt on a PT and have had to tear it back apart, again. Dealership rates in my area (Dallas/Ft. Worth) are about $125/hr and the job takes about 8+ hrs. Last edited by rckstein; 28 Dec 2015 at 05:33 pm. |
Not to far in the future you will also need to change the radiator/condenser fan.
They seem wear out around 110,000 miles This is something you should be able to do of find some some one to do it much cheaper than the dealer.
And then there are the PT Cruisers going on 200K without ever having changed the timing belt yet
![]() I do not think that a belt in a operating location as the 2.4 and getting 100k+miles out if it is a bad design necessarily? Now I can tell you of a popular modern designed engine in the last 12 years that does have a timing belt assembly that wears out in as little as 40k miles and the manufacture recognizes it. But no recall yet. ![]() I would like to see when they mention the repair quotes to post the exact itemized estimate. Most of the time when that happens you find there is much more then what is being told on the estimate. |
Thread Tools | |
Display Modes | |
Timing Belt Replacement | MarkB | Tech & Performance Forum | 108 | 08 Aug 2017 12:59 am |
[Q] Timing belt replacement | MadCobbler | Tech & Performance Forum | 6 | 02 Jul 2015 10:19 am |
Timing belt replacement | dewey68 | Turbo Performance | 13 | 16 May 2012 09:53 pm |
Timing belt shield, belt replacement. | jdwalk04 | Tech & Performance Forum | 13 | 14 May 2012 10:01 am |
Timing Belt Replacement - What Next? | johnjsa | Tech & Performance Forum | 5 | 22 Feb 2012 05:22 pm |
