I need to replace the gas filter. What should I buy exactly
Like Tree2Likes
  #11 (permalink)
Old 01 Jan 2016, 05:41 pm
Default Re: I need to replace the gas filter. What should I buy exactly
You're not one of those people that routinely keep clicking the handle when you fill up are you? If so, STOP IT! The filler neck is designed to do this to keep you from effing things up. It stops for a reason. You may have a leak at the point where the filler neck enters the tank or more as I suspect the reason you're smelling gas is because you've saturated the charcoal filter in the charcoal canister. Not a good thing.
Tags
gas filter, gas pump
Replace Crankshaft Sensor when you replace Cam Sensor falconut Tech & Performance Forum 7 14 Oct 2015 08:43 am
replace alt ptsw PT Cruiser Convertible Forum 2 16 Oct 2011 05:14 pm
FS K&N Air Filter, Purolator Trans Filter fljohnboy Classifieds: For Sale/Trade 1 02 Feb 2011 11:18 am
Issue With my 2001 PT Air Filter/Fuel Filter/Tranny Rekoj Tech & Performance Forum 7 10 Jul 2009 12:27 am
TSB - replace PCM GTSteve General Turbo Discussions 28 23 Jun 2004 06:17 pm
