Bulb Replacement Chart
Like Tree8Likes
Old 01 Jan 2016, 03:02 pm
War_Eagle's Avatar
Default Bulb Replacement Chart
I'm not sure if this is the right place for this but I was looking for these and figured some others may be as well. It has the majority of the bulbs for our application.
Home Applications Automotive Lighting Systems Lamp Replacement Guide View All Bulbs
Part #s and Upgrades available for: CHRYSLER PT Cruiser
ApplicationPart #SilverStar UltraSilverStar zXeSilverStarXtraVisionZEVOSilverStarLongLife
Ash Tray Light Bulb 37
Back Up Light Bulb 3157
Brake Light Bulb 3157
Center High Mount Stop Light Bulb 921
Dome Light Bulb 578
Headlight Bulb High Beam 9005XS
Headlight Bulb Low Beam 9006XS
License Light Bulb 168
Map Light Bulb 578
Side Marker Light Bulb Front 4157NA
Side Marker Light Bulb Rear 3157
Tail Light Bulb 3157
Trunk or Cargo Area Light 904
Turn Signal Light Bulb Rear 3157
Turn Signal Light Bulb Front 4157NA
Fog Light Bulb Front 9006
Parking Light Bulb 4157NA
The applications presented in this replacement guide have been compiled using the best information available from the vehicle manufacturers at the time of your search. This guide is intended for general information purposes only, not to be construed as any type of warranty as to any particular application. For specific applications the vehicle owner's manual should be consulted.
When two or more lamps are listed for the same application, remove the lamp and check the numerical designation.
wwpptc, ColTED, Fk5 and 4 others like this.
Old 19 Jan 2016, 08:54 pm
Default Re: Bulb Replacement Chart
Dome Light Bulb 578
Map Light Bulb 578
Nice find. Most owners will refer to their drivers manual for the listing of all the bulbs in their PTs but thanks for effort to share this with us. If nothing else it will be useful (if not absolutely necessary) with the owners that don't have an owners manual. Since the new owners these days have purchased their PT's used, most of the time the owners manual was lost long ago, so again thanks!
We appreciate it.
Jerry
Old 20 Jan 2016, 12:17 am
War_Eagle's Avatar
That's the very reason for the post. My 05 did not have any literature with it.
2005 Silver GT, auto, black leather, HID Headlights, ST Front sway bar, 215 45/17 tires, dark tinted front windows, stock running gear, sickspeed black pearl shift knob.
Old 20 Jan 2016, 02:08 am
Is this chart specific for 2005? For example the tail lamp part number is 3157-P27/7W for the 2005 PT Cruiser from the 2005 Parts Catalog.
There are different bulb numbers depending on if you have a 1st generation or 2nd generation so its better to look up the bulb number in the Part Catalog so that there is less confusion.
Old 20 Jan 2016, 09:16 am
about headlights....
GE Nighthawk Platinum or Philips XtremeVision are both a better, brighter choice than the sylvania silverstars.
they will be brighter and they will last longer, yet neither is higher wattage than stock.
i just ordered a set of the Philips bulbs for my beater. if you want even brighter lights, you can power them with relays and 10awg wire. even just bypassing the melt-prone C103 connector under the dash made mine noticeably brighter.
Old 08 Apr 2016, 09:21 pm
So my 02 requires 2 separate sets of bulbs. That will get expensive. I have a set of silverstar ultras on clearance tonight, but it was only the low beams.
Old 08 Apr 2016, 10:39 pm
_PTGT03's Avatar
so which manufacturer's are these part numbers ?
Dome Light Bulb 578
Map Light Bulb 578
Old 28 Apr 2016, 09:15 pm
Can you explain this install further ?....Did you have to remove tires ?
I learn something new everyday I listen.
I don't know half as much as I thought yesturday.
Today wasn't as scary as I expected.
Tomorrow is simply just that, not today.
Imagine getting up from dinner w/o warning and going into harms ways. Comming back doing it for breakfast, lunch and each day.....till told StandFAST !
Thats a MARINE
Your sons,daughters,husbands,wives,Brothers and Sisters.
Old 28 Apr 2016, 09:58 pm
It's easier if you take the front wheel off but not necessary. If you turn the wheel outwards your see a rubber access door like in the picture below. Once that door is removed (pried out) you have access to the headlight and turn signal bulbs.
here's a U-tube video of the process..
Old 29 Apr 2016, 03:35 pm
Ghosttowncs's Avatar
Holy smokes, a 9006 for the fogs? No wonder they actually work! Haha
Bag O' Corn Friend!
2002 Limited, Auto, 142k miles
07 fog light bulb replacement Shiniquiet Exterior Accessories Forum 10 03 Dec 2014 07:24 pm
Instrument Panel Bulb Replacement intim3 Interior Accessories Forum 23 10 Apr 2012 10:55 pm
headlight bulb replacement mellowyellow General PT Cruiser Discussions 3 06 Mar 2007 10:33 pm
Vanity Mirror light bulb replacement Bren Turck General PT Cruiser Discussions 2 25 Jan 2004 08:46 pm
