My PT won't start (I'm boiling with anger)
Old 01 Jan 2016, 03:17 pm
Default My PT won't start (I'm boiling with anger)
Hello,
This is not only my first PT Cruiser but also the first time I've ever owned a Chrysler and I'm not enjoying the experience. From alternators that require the removal of the drive axel to changing signal lights from the wheel well.
Ok about a week ago my car had a parasitic load that drained the battery. The problem is in the interior lighting. However the weather was turning bad so I charged up the battery and pulled the car in to the driveway and disconected the fuse. (got a no DRL fuse error when I did so) Long story short I took the battery out of the car and waited until today to try and fix the problem.
Today I went to troubleshoot the parasitic load.
I removed the fuses to look at them to see if there was any blown. None including the IOD. (All fuses good)
Noticed that the last owner jacked a wire from the 20A radio fuse to where the radiator fan high relay should of been.
So I changed nothing.. didn't undo a darn thing... she was working fine before.
However the car won't start. It cranks, there's spark and I can hear the fuel pump pressurizing. The car obviously "wants to start" but she just won't catch. It's as if she's stuttering or tripping over her words.
2003 PT Cruiser - No Turbo - 160kms
Trouble codes from the engine are P0517 (Battery Temperature Sensor) and P0038 (The downstream heated O2 sensor)
I can not see how either of these 2 errors could cause a no start problem.
Old 01 Jan 2016, 03:32 pm
Default Re: My PT won't start (I'm boiling with anger)
The plugs may be burned to the point of mega gap. Check that. Also if you have fog ligts the stalk switch gets worn and leaves the fogs on after you turn the car off. We have a repair for this in the performance section called ho to.
Yes there will be some issues when you have a unique body style that minamizes access to replacing parts. being used. Not all previous owners do their maintenance. So you get left what they didn't do. Happens on all brands. So if you don't love the style and attributes of the cruiser enough to work around the tight mechanical space. Then you may want to go more mainstream body style. Just a thought.
Old 01 Jan 2016, 03:36 pm
Plugs are new (did them myself)
No fog lights
As for the rest I'm stuck with the car. I can't afford a new one
Old 01 Jan 2016, 03:42 pm
Ya.. um Welcome to the forum??
Lets try this?
Missing Antenna Question
and then
WELCOME and Forum Rules
^^^^^specifically read this!^^^^^
We encourage all new members to say hello and introduce yourself to the rest of the community by starting a post in the Welcome New PT Owners thread at the top half of the forum.
Old 01 Jan 2016, 03:52 pm
Originally Posted by PT2003Montreal View Post
Hello,
we are here to help, boiling will never start a PT Cruiser, please year, miles, NA?
Try starting fluid while cranking, injectors will only operate for fuel delivery if they get a signal, from computer, do you have remote start??
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 01 Jan 2016, 03:53 pm
[/B]
Thank you and sorry if I stepped on anyone's toes by being so abrupt. I guess I'm a little obessed at this moment with solving my problem.
Originally Posted by JoeX View Post
we are here to help, boiling will start any PT Cruiser, please year, miles, NA?
Year : 2003
Millage : 160k kilometers.
No Turbo
No remote starter
Tried starter fluid while cranking.
Error codes : P0517 and P0038
Busted_PT likes this.
Old 01 Jan 2016, 05:32 pm
The 0)517 is the Battery Temp Sensor. Under the battery tray. Why? I have no idea. Here's the info on the other (p0038) P0038 Chrysler - O2 Sensor 1/2 Heater Circuit High - OBDII Engine Light Trouble Code | AutoCodes.com
Old 01 Jan 2016, 06:03 pm
But an OS sensor should not stop the car from starting.
Old 01 Jan 2016, 06:40 pm
Hello,
I would suggest taking a voltmeter and check the voltage on both sides of all the fuses you took out and put back in.
Also do a battery load test. When you took the battery out you might have disturbed some other wires. Your battery might have been affected by the parasitic load drain.
Did you try starting the PT Cruiser after you put the battery back in or did you pull the fuses first and then try to start the PT Cruiser?
Old 01 Jan 2016, 06:48 pm
Originally Posted by ptcruisersteve View Post
I would suggest taking a voltmeter and check the voltage on both sides of all the fuses you took out and put back in. .
Already did it... No problems found
Battery reads 12.66 before test
Battery read 9.97 under load.
I've checked.. rechecked.. double checked... and triple checked.
Help!! Another over heating problem!! :anger: cruiser07 General PT Cruiser Discussions 94 28 May 2016 07:11 am
2004 PT Boiling Over Help 2004 Tech & Performance Forum 10 18 Dec 2010 01:43 am
Coolant Boiling Over jorgesag Tech & Performance Forum 6 10 Oct 2010 10:15 pm
Car is off, Boiling Coolant ptcruzrmama General PT Cruiser Discussions 17 15 Aug 2010 12:21 pm
