noise/vibration at speed
Like Tree2Likes
  • 2 Post By rob342
Old 05 Jan 2016, 05:38 pm
j0e j0e is offline
Default noise/vibration at speed
So, I get this irritating hum and vibration while driving.
It's most noticeable over 40 mph.
I'm thinking wheel bearing?
It kind of "sounds like" bad road noise or an exhaust drone.
I thought I had a bad tire so I did a rotation to see if the noise would move, but no luck.
Also, it seems to go away while turning right.
What do you gents think?
Old 05 Jan 2016, 05:42 pm
Default Re: noise/vibration at speed
go drive 40-50mph and gently swerve right and left. if it gets loud one way and quiet the other, you know you're correct
i let mine go until the keys were jingling in the ignition
quicksilverdon and j0e like this.
Old 05 Jan 2016, 06:13 pm
j0e j0e is offline
Yeah. That's what I thought.
Turning right makes it stop.
So, that means it's a left bearing?
I think front because I can feel it in the floor.
Old 05 Jan 2016, 06:39 pm
i couldn't tell you which. that always confuses me.
i do know that about a month after i changed one on mine, the other started humming. i believe this is common, so you might just do both
Old 07 Jan 2016, 02:11 pm
j0e j0e is offline
Thanks man.
I wonder if this is something I want to tackle?
Probably should go to a pro...
Grinding noise and vibration. Jnskathy General PT Cruiser Discussions 7 29 Jan 2014 02:42 pm
Noise/Vibration When Accelerating NewPTCruiserInPA Tech & Performance Forum 10 14 Dec 2013 03:01 pm
Slight vibration in steering, squeaking noise coming from wheels, thud when braking thinkinboutit General PT Cruiser Discussions 6 10 Oct 2010 11:31 pm
Low speed noise ? Why42 General PT Cruiser Discussions 1 30 Jun 2010 08:47 am
GT 5 speed clutch noise or " clutch chatter". boosta General Turbo Discussions 3 11 Aug 2003 08:10 pm
