Tail Light Problems
Old 06 Jan 2016, 09:33 am
Default Tail Light Problems
Hi everyone! I have an 08 PTC.
I went to change my right breaklight this morning because it was out. Changed the bulb, still won't go on. Is there anything I should check (like the fuses) before I bring it in to get looked at?
Thanks!
Old 06 Jan 2016, 09:38 am
Default Re: Tail Light Problems
Have you checked for bad ground?
Have you checked for 12 volts?
Old 06 Jan 2016, 09:41 am
Haven't done either. How would I do that?
Old 06 Jan 2016, 10:40 am
You will need to get an voltmeter.
If you put your hazard lights on does the problem tail light come on?
Old 06 Jan 2016, 10:48 am
When the hazards are on, the tail light is still off. I'm wondering if it's the socket maybe?
Old 06 Jan 2016, 10:57 am
It could be the socket. BUT are you sure you used the correct # replacement bulb? If the bulb is right, did you make sure it locked in? Most of the bulbs have a high nub and low nub on them and if you don't put them in the right position, the bulb is simply not clocked right and won't make contact with the points in the socket.
Old 06 Jan 2016, 11:03 am
Hmmm. That sounds like something I would do. Will check it on my lunch break! Thanks
Old 06 Jan 2016, 11:13 am
LionPT's Avatar
Try the bulb on the other side to see if it works or not.
Old 07 Jan 2016, 08:21 am
I hope he comes back and lets us know what he found out.
Old 07 Jan 2016, 10:34 am
Very often the sockets burn up and loose connection
Brake Light Condensation/Tail Light Replacement? NewPTCruiserInPA Tech & Performance Forum 3 23 Jul 2012 09:05 pm
Tail light problems and help would be appreciated Kingrampage Tech & Performance Forum 2 11 Aug 2011 11:08 pm
Mork's Tail Light and Reverse Light Tint Progress Morkeste Exterior Accessories Forum 30 23 Jun 2011 12:20 pm
tail light broken, but brake light works dirtydmix General PT Cruiser Discussions 8 09 Mar 2011 09:59 pm
