So I got the dreaded P0340 code today
Like Tree5Likes
  • 3 Post By podo2000
  • 1 Post By CREWZIN
  • 1 Post By podo2000
Old 06 Jan 2016, 07:55 pm
podo2000's Avatar
Default So I got the dreaded P0340 code today
I was almost home when the CEL came on and the car began to buck. UG tells me pending trouble code P0340.
Lurking thru the boards, i know its the cam position sensor or timing belt. But since the car was still running, it had to be the sensor.
Did a quick search on the boards to find out more about it and where it was located.
Took it apart, cleaned the contacts ( it was full of oil) and checked all the wiring. Put it back together and car is running great again. 20 mile test drive and no CEL
Thank you guys for posting on this site to enable us to be able to make quick fixes like this.
2004 PTGT 135Kmiles
Old 06 Jan 2016, 08:27 pm
Default Re: So I got the dreaded P0340 code today
That's the whole reason for the forum. Glad it was that easy for you.
rckstein likes this.
Old 07 Jan 2016, 08:17 am
Wait! Did you actually take the sensor apart or just cleaned the contacts in the electrical plug connector? I didn't know the sensor came apart. If so, I may try that with mine. Still has a slight miss that I can't seem to locate or eliminate. Maybe there's oil in mine too.
Old 11 Jan 2016, 09:49 pm
podo2000's Avatar
Sensor comes apart at the block. 2 10mm ( i believe) bolts
chuzz likes this.
2004 PTGT 135Kmiles
the dreaded p0551 code - stumper djfox1 Turbo Performance 17 16 Apr 2016 08:14 pm
Exchange of Information.. Dreaded CAS Code!!! Read. GTCRUISER2006 Tech & Performance Forum 4 18 Jul 2015 06:52 am
Car died today - Error P0340 BlakeL General PT Cruiser Discussions 5 02 Mar 2015 10:16 pm
Code P0340 flcruiser General PT Cruiser Discussions 1 24 Aug 2012 07:08 pm
the dreaded p0344 code ev3 Tech & Performance Forum 8 02 Apr 2011 02:44 pm
