03 Cruiser not shifting
Old 06 Jan 2016, 09:19 pm
Default 03 Cruiser not shifting
I have an 03 cruiser that has started acting up. when you take off, it gets to the shifting point then seems to go into neutral but still seems to be slightly pulling like it is slipping when you slow down. I read something about safe mode and locking in second, but i dont seem to ever get to second.
Old 07 Jan 2016, 09:23 am
Default Re: 03 Cruiser not shifting
Have you checked your transmission fluid level?
Is your engine light on? If so what are the engine trouble codes?
Old 07 Jan 2016, 04:49 pm
fluid is full and no check engine light and no code showing up with key test.
Old 10 Jan 2016, 02:44 pm
UPDATE! with further testing and driving, I have determined that the cruiser is not going into limp mode, i have no second gear. If i keep the shifter in first, it is strong and keeps pulling. when i have the shifter in a higher gear, as soon as it hits second, i have nothing. put a new output sensor on( just happened to have one)and a solinoid pack from wrecked vehicle. still the same.
Old 10 Jan 2016, 05:13 pm
A correct diagnoses of a transmission problem when there is no check engine light is best accomplished with a professional transmission scan. This type of scan will require a Starscan or a scanner tool that the dealers use.
There might a possibility that you might have an internal TCM failure but you need to verify if there are transmission codes that is stored.
pt cruiser automatic shifting problems buzzbomb General PT Cruiser Discussions 2 09 Nov 2012 11:55 pm
lost all shifting ability on 2004 PT cruiser ptloverfl Welcome New PT Cruiser Members 3 13 May 2012 10:34 pm
PT not shifting out of first gear. Jables General PT Cruiser Discussions 5 18 Oct 2010 11:34 am
2002 pt cruiser 5spd pops out of 5th gear and hard shifting bobby515 General PT Cruiser Discussions 3 03 Jun 2008 08:39 am
Twin Turbo PT Cruiser Power Shifting - Funny skylight PT Cruiser Videos 0 11 Nov 2007 07:00 pm
