Speedometer/Odometer/trans. jerky
Old 07 Jan 2016, 08:18 pm
Default Speedometer/Odometer/trans. jerky
05 PT Turbo Convertible-Speedometer and odometer stopped working.
Trans goes into limp mode occasionally. When that happens, I pull off the road
and restart engine 2-4 times and it starts shifting ok...still some jerkiness upon shifting, sometimes.
I just installed new output speed sensor. Seems to shift better (smoother) but
speedometer and odometer still not working.
Any suggestions?
Thank you,
Paul
Old 07 Jan 2016, 09:12 pm
Default Re: Speedometer/Odometer/trans. jerky
I would suggest checking the wiring going from and to the TCM.
If the wiring is okay you might have lost the pinion factor programming in the TCM and you need to have it reprogrammed.
manual trans. code p0501 - speedometer not working shelbyzman Tech & Performance Forum 3 02 Jan 2014 04:26 pm
Odometer problem, speedometer working fine freshman6969 Tech & Performance Forum 11 08 Jul 2012 03:56 pm
2003 GT engine light on, jerky when shifting johnnybassman General PT Cruiser Discussions 4 12 Jan 2012 03:24 pm
2006 PT - Speedometer AND Odometer not working SweepTheLeg Tech & Performance Forum 8 04 Sep 2009 04:33 pm
A little jerky wachikinow General Turbo Discussions 8 22 Aug 2009 10:04 pm
