stalling low rpm
Old 08 Jan 2016, 09:38 am
Default stalling low rpm
Hi my 2001 cruiser runs great with 80000 miles however periodically when first starting it does not see to hold rpm and stalls.it will start up again but may stall once again due to low rpm.this does not happen very often but can be annoying for my wife.no engine light comes on and dealer changed coolant temp sensor could not find problem.has anyone come across this problem
Old 08 Jan 2016, 10:48 am
Default Re: stalling low rpm
There are many, many issues that can be related to poor idle. Are you getting any engine trouble codes?
Does it still have the idling problem with the A/C off? If not you might have a problem with your radiator fan or A/C.
If the rpm does not increase approximately 100 rpm when the ac is turned on while idling I would suggest checking the IAC and see if it working properly.
Any obstructions to the intake airflow? Is your air filter clean?
One item that directly affects idle is the throttle body, if it's not clean, you're not going to get a good idle.
The other thing is your Oxygen sensors. If one is not working properly, it will be reporting improperly back to your engine's computer, causing it to mal-adjust your throttle speed. The engine trouble light should be lighted if this is happening.
My suggestions would be to check your air filter and clean your throttle body first. Post back what the results are.
By the way you should introduce yourself to the forum. Tell us a little about your PT Cruiser.
car stalling. redcruiser03 Tech & Performance Forum 3 14 Oct 2014 07:28 am
Stalling.... Unshriven Tech & Performance Forum 5 14 Mar 2010 10:02 am
Stalling Vicki120 Tech & Performance Forum 4 14 Feb 2010 07:43 pm
stalling natesoukup General PT Cruiser Discussions 3 11 Dec 2009 03:45 pm
Stalling sifu_scott Tech & Performance Forum 2 10 Dec 2007 05:35 pm
