No brake lights
Old 10 Jan 2016, 11:39 pm
Default No brake lights
All 3 brake lights out. Tail lights and blinkers work. Tried replacing my brake light switch and it only got my car stuck in park (2 different new switches, same outcome) It's a 06 basic Cruiser... Is there any special procedure to this switch? I took the old one out, put new ones in & set lever... Is there a fuse or relay that could help? I suppose I have to change the switch anyway even if i wasn't the problem because I ended up putting the old one back on to shift from park. Sorry if this is unclear in any way. Any advice is appreciated! Thank you!
Old 11 Jan 2016, 08:19 am
Default Re: No brake lights
Yeah, it's really not clear on why you tried the switch. Did you check the bulbs first? If so and they're all good, did you check for power to the sockets next? Did you check the fuse box? Brake light switches are usually the LAST place to look. Do the tail lights and hazard lights work? What about your turn signals? You need to give us all the information you have and everything you've tried.
Old 11 Jan 2016, 10:03 am
The tail lights work.. I'm sorry to be so ignorant to the concept, I assumed that they were the same bulbs with more power sent making them brighter if the tail lights are on to indicate braking.. And since all the lights are out, even the one up top I thought it had to be a fuse or the switch. I can't find a fuse that indicates brake lights and the Internet hasn't helped so I'm turning to this forum, I had a Blazer previously and the forum for it helped me a lot.
Old 11 Jan 2016, 10:05 am
Also as previously stated the turn signals and tail lights work.. As do the hazards
Old 11 Jan 2016, 10:28 am
LionPT's Avatar
stop lights not working...
Old 11 Jan 2016, 01:03 pm
Yeah that's something I can show to the mechanic if I have to, that's a foreign language to me. I'm more curious to whether or not there is a a fuse it relay, and to what is going on with these new switches. Thank you though!
Old 11 Jan 2016, 01:04 pm
*fuse or relay
Old 12 Jan 2016, 01:35 am
What brand brake light switch and part #? Have you verified its the right brake switch replacement?
Does the replacement brake light switch have instructions on how to install it?
Old 12 Jan 2016, 12:30 pm
Its off (not manufacture) brand, I have tried 2 and they do the same thing. There are instructions included. I followed them, removed the old one, put the new one on and set the lever.. both times the car would not go out of park.. put the old one back on and it goes out of park. No brake lights though. Is there a fuse or relay?
Verified as correct part for my vehicle though.
Brake lights wont work, 3rd brake does Dill General PT Cruiser Discussions 17 03 Oct 2016 04:34 pm
new to me '06 Touring tail lights & brake lights are out twodees General PT Cruiser Discussions 14 18 Dec 2015 10:15 pm
No Brake lights or tail lights/running lights kitzmann56 General PT Cruiser Discussions 8 14 Feb 2015 03:07 pm
TAIL LIGHTS ND BRAKE LIGHTS NOT WORKING mccloud12 Tech & Performance Forum 7 12 Jun 2014 06:21 pm
HELP! '02 Cruiser with no tail lights, then no brake lights. tschauer Tech & Performance Forum 1 16 Sep 2010 05:54 am
