'02 PT Cruiser rear brakes locked up
Old 11 Jan 2016, 10:55 am
Cool '02 PT Cruiser rear brakes locked up
Oh, heck...my brakes are locked up after it sat for 4 weeks. This had apparently happened with the previous owner, who assured me just backing up and then going forward, repeatedly, would unlock them. Needless to say it's not worked. They are locked solid either direction. So, unless I want to wear my tires out I need other options. The caliper (driver's side) was replaced recently and he said everything looked good. Thanks!
Old 11 Jan 2016, 12:50 pm
wingman55's Avatar
Default Re: '02 PT Cruiser rear brakes locked up
I am assuming that you have rear disc brakes by your comment about the caliper being replaced.
I had an '83 Imperial that would do that. I'd let it sit over the winter and the calipers would stick when I tried to drive it.
One thing that you could try is to get a medium-sized hammer, and tap on the calipers to try and vibrate them loose. Don't hammer away on them, just get under there and tap in various placed on the calipers (not the discs).
Maybe raise it up on jack stands to get at them, and try rotating the wheels by hand after each few taps.
I hope this helps.
2006 Limited Edition, Inferno Red, 5-speed, Bassani dual exhaust, Chrome backup light bezels, taillight trim, fuel door, antenna mount, Ventiports, door spear covers & hood prop. Silver painted lower front grille. American Racing 383 Casino wheels, w/Chrysler emblems, '02 engine cover, PT Cruiser mudguards, cargo mat. EGR Window Visors, dark gray lock pulls, dual horns, Fuzzy Dice, flames and MOPAR emblems added to front door logos, gold Chrysler emblem on rear hatch. Upgraded to RAK radio with 6 CD changer, Cassette Tape and RDS info. Name: "FIREBALL" I bought it Aug 10, 2015, with just over 35,600 miles on it.
Old 11 Jan 2016, 01:04 pm
front brakes or / and back brakes??
Parking brake?
Do you have disk on all 4 wheels?
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 11 Jan 2016, 06:09 pm
Rear brakes? Did you park it with the emergency brake engaged? If so, that's most likely what the heck is frozen.
Old 12 Jan 2016, 10:10 am
No, I don't use my parking brake. Rear only are locked. I'll give the hammer tappingva try. Well, I'll have a friend do it. (Recovering from surgery).
Thank you for your speedy replies! 🚦
Old 12 Jan 2016, 11:10 pm
Are both rear brakes locked or just one side?
Tags
#brakeslocked, #ptbrakes
04 pt cruiser rear drum brakes hand brake don't work Bandit2014 Wheels, Tires, Suspension 0 25 Mar 2015 01:19 pm
01 Cuiser brakes locked up and idle is odd! invidious General PT Cruiser Discussions 12 01 Nov 2014 07:17 pm
Rear Seatbelt locked with seat folded flat WonderMur General PT Cruiser Discussions 9 03 Nov 2013 11:00 pm
2004 PT cruiser rear brakes, adjustment wheel problems 20GT Wheels, Tires, Suspension 5 10 Nov 2012 04:06 pm
Brakes failed and steering locked in my cruiser chellabella General PT Cruiser Discussions 5 02 Feb 2008 08:56 pm
