05 turbo two codes-what to do?
Old 16 Jan 2016, 12:09 am
Default 05 turbo two codes-what to do?
Recently replaced output speed control because engine check light was on,trans was shifting a little jerky and occasionally going into limp mode.
Speedometer/ Odometer not working.
After replacing output speed control, check engine light went off, trans started shifting properly, but speedo/odometer still not working.
About 7 days ago check engine light came back on with codes P0455
and P0501.
Should I replace input speed sensor as well?
Would a bad input speed sensor cause the speedo/od to not work?
Help...
Thanks,
Paul
Old 16 Jan 2016, 01:29 am
Default Re: 05 turbo two codes-what to do?
P0455 - EVAP Large Leak Detected Conditions:
Possible Causes:
1. EVAP purge solenoid is damaged or it has failed
2. Fuel tank cap is damaged, missing or the wrong part number
3. NVLD switch is damaged or it has failed
P0501 - Vehicle Speed Sensor Performance Conditions:
Possible Causes:
1. Check for any ABS/RWAL or TCM codes related to the VSS
2. VSS connector is damaged, open or it is shorted
3. VSS signal is open, shorted to ground or shorted to power
4. Incorrect tire circumference
5. ABS/RWAL controller, BCM, ECM, TCM or PCM has failed
I am suggesting you have two separate problems.
On the first problem I would check the Gas Cap.
On the second problem I would suggest checking the VSS connector. If that is okay I would try and borrow a scan tool that will read the TCM codes. Post back what you find.
What's the difference between Turbo engine codes B, G ane E irieite Tech & Performance Forum 24 16 Apr 2015 11:09 pm
Error codes in 2004 Turbo mycar Tech & Performance Forum 0 14 Aug 2014 01:48 pm
error codes turbo bheffner General Turbo Discussions 2 05 Feb 2014 03:27 pm
PT GT Turbo crapped out, 7 error codes cbohlson General Turbo Discussions 11 28 Feb 2010 08:10 pm
Checking codes on 2003 PT GT Turbo Greenie General PT Cruiser Discussions 12 02 Mar 2009 03:58 pm
