Engine shaking normal?
Like Tree3Likes
  • 2 Post By ptcruisersteve
  • 1 Post By ptcruisersteve
Old 17 Jan 2016, 06:15 pm
Default Engine shaking normal?
Why does these cars seem to vibrate at idle In gear or is it just me? I've replaced upper and lower engine mounts they looked weak and were on the weak side but it still vibrates in gear. Is that just how unrefined these cars are?
Old 17 Jan 2016, 07:26 pm
Default Re: Engine shaking normal?
Did you follow the alignment procedure per the factory repair manual after replacing the upper and lower torque struts?
Old 17 Jan 2016, 07:58 pm
Handy_Cruiser's Avatar
+1
Yes. Make sure you have 12 centimeters between the alignment hole and the top mount bolt. Here's a photo of the measurement from my PT:
Old 17 Jan 2016, 08:07 pm
Ehhhh, I haven't checked mine. If it's NOT lined up, how do you get it there?
Old 17 Jan 2016, 08:34 pm
I checked it now , it has 6in from the very first hole to the very first bolt on the mount.
Old 17 Jan 2016, 09:06 pm
Free 01-04 PT cruiser shop manual
Page 1198 of this shop manual indicates 119 mm or 4.700 inches. Look at the image that shows the measurement on fig. 104 and where the measurement is taken from. Be careful as my PT Cruiser used the first shock tower bracket hole for another bracket to hold up another component.
Old 18 Jan 2016, 01:32 am
If you go to page 1197 and look under Engine Torque Strut Adjustment it will tell you the step by step on how to adjust the torque struts. Fig 103 on page 1198 shows the proper way to use a floor jack to get the right upward lifting of the engine. You will need a small size block to get enough clearance to not bind when raising the engine.
3rcruiser likes this.
Shaking in Park & Check Engine Light sarahajoseph09 Tech & Performance Forum 3 31 Mar 2012 12:38 pm
Hissing sound from engine. Is this normal? HYE_PTC General PT Cruiser Discussions 5 24 Jun 2011 07:33 pm
Shaking, jerking & engine light eileenb Tech & Performance Forum 7 27 Mar 2011 09:50 am
Engine surging at 4000 RPMs along with shaking at 2000 RPMs... brian5060 Tech & Performance Forum 3 24 Jul 2010 07:42 pm
normal ? 4SPEED General Turbo Discussions 12 26 Sep 2008 11:52 am
