Fog lights?
Like Tree3Likes
  • 1 Post By Handy_Cruiser
  • 1 Post By CREWZIN
  • 1 Post By sanatanadharma
Old 25 Jan 2016, 01:22 pm
Default Fog lights?
Hi everyone new member here. Just bought a 2003 2.0l cruiser which I love.
However my front fogs wont go on. Have checked the bulbs, i know how to get them on. Read a few things on line and I can sat I dont have a fuse #8 on the internal fuse and the fuse under bonnet as far as i can see is ok.
Any ideas anyone. Also can i ask why woyld have fuse for heated seats but no switch for that function.
Thanks.
Old 25 Jan 2016, 01:50 pm
Handy_Cruiser's Avatar
Default Re: Fog lights?
Welcome to the forum from the great sovereign state of Arkansas!
If the #8 Fuse slot is empty, put one in and see what happens. On some PT Cruisers, the multi-function switch that controls the fog lights will fail. When failure occurs, the fog light often stay on all the time. The previous owner may have just removed the fuse so the fog light would go out.
If you install the fuse and the fog lights come on even though the switch is off, you likely will need a new multifunction switch or you will need to repair yours.
Sorry for the large image below, but it was already in the forum gallery this way:
Old 25 Jan 2016, 02:14 pm
Thanks. There are no connectors in fuse #8 for a fuse to stay in place so even more confused.
Old 25 Jan 2016, 02:24 pm
First, things could always be different on the non-US PT Cruisers. I'm going off the assumption this fog light stuff works the same way.
Check the lid of your fuse box and assure fuse #8 is indeed for the fog lights. If so, there's a good chance your PT did not come with them from the factory but were added later. If that's the case, check the multifunction switch to see if it even has a switch for the fog lights. If it does not, then your fog lights may have been wired a different way with an aftermarket kit or not wired up at all.
If there is a switch for the fog lights, then you may be dealing with a custom or dealer install. If so, I would start at the fog lights themselves and follow the wires back up to see what is going on.
ptprice likes this.
Old 25 Jan 2016, 02:39 pm
According to my owners manual, on the overseas PT Cruisers, the No#21 fuse is for Fog Lights on the Export Models. That's in the PDC (Power Distribution Center) under the hood (Bonnet) of the 01-05 First Generation cruisers.
Handy_Cruiser likes this.
Old 25 Jan 2016, 03:09 pm
There is a switch for the fog lights as the rear one works with same switch. Fuse #21 is also intact under the hood.
Old 25 Jan 2016, 03:13 pm
Well, the fuse mystery is solved. If I understand this right, there's a rear fog light and it works? If so, I'd get a test light and check for current at the front bulb sockets. Then I'd work my way back for there.
Old 25 Jan 2016, 05:05 pm
Ok thanks for your help. Do you think it could still be the multifunction switch
Old 25 Jan 2016, 07:39 pm
Because Trump
ptprice likes this.
Old 26 Jan 2016, 03:47 am
Ye according to my diagram i do have heated seat fuse both in car and under bonnet. Strange
my door locks,head lights and tail lights don't work. bones02 Tech & Performance Forum 38 06 Apr 2016 10:30 am
Tail lights, dash lights, a/c panel lights not working ZZCruizer Tech & Performance Forum 12 14 Dec 2015 11:11 pm
ABS, traction lights, parking break lights ON and Cruiser control doesn't work Fab Feedback and Support 0 08 Jun 2015 08:28 pm
No Brake lights or tail lights/running lights kitzmann56 General PT Cruiser Discussions 8 14 Feb 2015 03:07 pm
Need a poll answered: Should I tint all my lights or buy euro/projector lights? 85_305 Exterior Accessories Forum 2 17 Jun 2009 08:38 pm
