Reverse lights
Old 26 Jan 2016, 02:25 pm
Default Reverse lights
Right so today seen my reverse light wasnt working, checked bulb fuse etc all fine. After investigation it turns out if i shift into reverse then lightly nudge the gear lever the light comes on. How can i fix this?
Old 26 Jan 2016, 07:45 pm
rcktpwrd's Avatar
Default Re: Reverse lights
which transmission, auto or manual?
Joel
www.rcktpwrd.com
Old 27 Jan 2016, 01:10 am
Sorry manual
Old 27 Jan 2016, 09:00 am
rcktpwrd's Avatar
probably a bad reverse light switch.
Joel
www.rcktpwrd.com
Old 27 Jan 2016, 09:17 am
Originally Posted by Stuart75 View Post
How can i fix this?
personally, i'd just shift into reverse then lightly nudge the gear lever
_______________________________________
alternatively you can replace the switch.
see page 12 here: http://www.ertyu.org/steven_nikkel/n...000/EPL_21.pdf
chuzz likes this.
Old 27 Jan 2016, 11:19 am
2step's Avatar
Well??... maybe not. If it was the switch, I'd think both reverse lights would be out. The problem has to be downstream of the switch. It could still be the bulb if the filament is broken but just touching, or the bulb contacts are corroded. Pulling the bulbs, switching them around, inspecting the sockets and grounds, etc. is worth a shot.
Old 27 Jan 2016, 01:38 pm
Thanks everyone. Changed bulbs, connectors around still same problem. Gonna look at switch at weekend.
Old 28 Jan 2016, 07:26 am
i read that as "the reverse light wasn't working". how do you gather he only means one of two is out. just curious what i missed. i re-read it and am still scratching my chin.
Old 28 Jan 2016, 06:46 pm
SPLNeon's Avatar
Is there any cable adjustment? It may just not be going as far as it needs to activate the reverse light sensor?! It could be a shifter bushing bad as well?! If it is an 06+ pt, you may need to reset the TIPM.
Fastest fwd PT Cruiser in Canada
Competition's paying the price.
03 PT GT. DSI canned tune, Weight redux, MH Racemaster Slicks/Rota Slipstream 15" 11.89at 115mph 1/4 mile
96 SOHC Neon Turbo
08 CSRT4. Realtune MS1K v1 pcm stg0 NSRT4 Injectors.
Old 30 Jan 2016, 09:40 am
i can not help you
but my lights are just not bright enough when i back it up at night ?
Smoked tail lights and reverse lights! chris15 Exterior Accessories Forum 15 01 Jun 2010 05:53 pm
Reverse Lights in '03 GunnerIke General PT Cruiser Discussions 1 13 Apr 2010 12:40 am
take out reverse lights? brightlight07 Exterior Accessories Forum 1 10 Mar 2009 06:11 pm
TYC Reverse Lights CHROMEDCRUISER Exterior Accessories Forum 20 02 Sep 2004 08:23 am
Lost Reverse Lights & Reverse Shift Bell wunderbluegt General Turbo Discussions 1 06 Jul 2004 10:12 pm
