Major Coolant Loss
Like Tree3Likes
Old 28 Jan 2016, 01:25 pm
Default Major Coolant Loss
2006 PT cruiser, non –turbo, 125xxx miles
Yesterday morning when dropping my kids off I noticed coolant dripping out from under the radiator on the passenger side. Checked coolant level and it was ok, so I went to work and parked the car. Checked on it at lunch and it was dripping on the drivers side. When I left work it looked like the entire contents of my coolant system were on the ground under and behind my car. I added distilled water and drove home (about 10 miles) and it never overheated it just barely made it over the halfway line (maybe there is a bright spot in Midwest winter).
I Drove to a friends garage last night and added more water to look for a leak but couldn’t see anything leaking. When I looked under the car I saw no obvious cracks or places where it was leaking from, just coolant kinda sprayed around on the bottom plastic part of the radiator and pooling in the metal bar directly under the radiator. Drove it around the block and looked again and I couldn’t see any leak. I had my car at the shop a few weeks ago and the mechanic did say that he noticed some slight seepage where the aluminum and plastic were crimped but said he didn’t see a major need to replace it at the time, just to watch it. My questions are:
-Is it possible that the radiator is only leaking when hot/under pressure? I am inclined to think that this is the case since after I added the water I never saw a leak.
-Could it be more than just the radiator? I did check the hoses last night and didn’t see any splits or cracks in them. Not really sure what to look for in terms of water pump failure or if that would even be likely given what happened.
-Would it be “normal” to go from what was described as slight seepage to a major issue such as this seemingly overnight? I would think it would have gotten progressively worse.
Thank you in advance
Old 28 Jan 2016, 01:40 pm
Fk5 Fk5 is offline
Default Re: Major Coolant Loss
I have been going through tons of coolant leaks myself on my 2003 over the past couple of years. The first was the radiator. It is fairly common for the seam to separate and leak. The water will hit the support and drip down wherever is the lowest point.
Make sure that the drain is closed, tight and the o-ring is sealed. Mine leaked from there once when they reused the o-ring.
If you are using water and it is cold, be very careful. If it freezes, it will expand and start cracking things. At that point you will be praying it is just the radiator.
Old 28 Jan 2016, 01:48 pm
Thanks for the quick reply.
I have read that the radiator leaking at the crimps is a fairly common problem, I was more curious that it would go from slight seepage to a full on draining of the coolant over the course of a day. I did check that the drain was closed. I'm not too terribly worried about it freezing I was able to borrow a car and I left it last night in a closed garage, also there must have been coolant left in the system somewhere because the water in the filler had a antifreeze tint to it.
Old 28 Jan 2016, 01:59 pm
LionPT's Avatar
Rent or buy a Coolant Pressure Tester. I chased down 3 leaks before I bought mine & it well worth the money. So far all of my leaks have been from loose clamps.
Fk5 likes this.
Old 28 Jan 2016, 02:30 pm
Fk5 Fk5 is offline
FWIW, mine seemed kind of inconsistent. It never really let loose, but it isn't like it lost the same amount of coolant per mile or minute run. At one point I actually bent the crimp up with a channel lock and it slowed for a bit, but I knew the time for a radiator was coming.
You can borrow one from auto zone and some of the parts houses. Leave a deposit and get it back when you return it. It solves the issue of it not leaking when the car isn't running/warm.
Old 28 Jan 2016, 02:35 pm
Just called the parts store in town, and I will be picking up a pressure tester after work. I don't know why I didn't think of that before. Thanks Lion and FK5
Old 28 Jan 2016, 03:30 pm
LionPT's Avatar
If the kit comes with the adapter, don't forget to test the cap.
Old 28 Jan 2016, 03:51 pm
It can happen over night , maybe that bumper block was a little high or someone may have backed into you leaving little or no visible damage, but enough to stress the crimps on the radiator..
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 28 Jan 2016, 06:39 pm
Joe,
On the wifes car there is link tube that runs behind the water pump that had a small pin hole that would leak more when hot. check that.
its the Chrysler PT Cruiser Cooling Inlet Tube
here is link on the forum of what i am talking about.
Water Pump Inlet replacement
Black 2004 and Silver 2005 Limited Edition, when all else fails "RTFM"!
Old 28 Jan 2016, 07:01 pm
If you do look under the engine for a coolant leak you should look for a white residue that occurs when the coolant dries off. This will give you a clue on the location of the coolant leak.
P0455 Major Evap Leak Major issue h_wingman Tech & Performance Forum 16 27 May 2018 12:03 pm
HELP, Major Oil Leak 06OregonCruiser Tech & Performance Forum 6 10 Jun 2015 06:05 am
Troubleshoot coolant leak: Photo of Coolant on top of engine radiator cap MarcusO Tech & Performance Forum 7 27 Apr 2013 09:16 am
2001 coolant loss mystery zip Tech & Performance Forum 40 29 Jan 2013 01:17 pm
Major coolant leak - Trying to figure out location? thec0wboy Canada PT Forum 7 24 Oct 2011 02:31 pm
