Use Empty Fuse Slot
Like Tree3Likes
Old 29 Jan 2016, 01:48 am
Default Use Empty Fuse Slot
First forum post here and hoping someone can help me.
I have an 07 and am wanting to semi-permanently install an electrical accessory. To do this, I could just connect it to the battery, I know, but I would rather run it through the fuse box (TIPM). There are a couple empty spots for fuses in mine that are acceptable. So what I want to know is the following:
Will those empty spots be live?
Can I just run a wire into those empty spots to access the power?
Will the TIPM dash my hopes and dreams?
Justs a heads up, I cannot do the easy Add-A-Circuit fuse piggyback because I will be running a high amperage fuse (40 amps).
Thanks in advance.
Old 29 Jan 2016, 03:16 am
Default Re: Use Empty Fuse Slot
In my opinion I would connect it to the battery with a fuse in line. Some of the members have had the TIPM fail so I feel the TIPM has design flaws in it. I feel the best thing to do is to leave the TIPM alone. It can be expensive to replace it.
JoeX likes this.
Old 29 Jan 2016, 07:18 am
Yes stay away from the TIPM, You should use a switch to control a relay protected with a fuse to power your add on.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 29 Jan 2016, 08:11 am
Ok, if I skip the TIPM and go straight for battery hookup, should I go fuse or circuit breaker? 40 amps is actually below the threshold for the inverter max draw by a little bit (but I wanted to give myself safety room, plus I should almost never reach 40 amps in normal use). I'm leaning toward a circuit breaker for the occasional peak draw on the inverter, as I understand circuit breakers are more tolerant of that. Just for clarity, by peak draw I mean the high momentary draw some devices do when they first power on.
Old 29 Jan 2016, 08:54 am
personally i usually only use breakers for headlights, power windows, and wipers. if you're overloading the inverter, changing a fuse is better as it helps prevent you from overloading it repeatedly. ie: you learn not to do that, much quicker. but to each his own.
breaker/fuse size should be determined by the rating on the inverter you're using, and also by the gauge and length of wire. not by our recommendations
look at the inverter documentation, determine how long the wire will be, and then look at the attached chart for help choose a wire gauge and suitable breaker.
if the wire is 6' long and you only have 12awg, you'd want a 30A. if you have the coin to buy 10awg wire and can keep the wire 6' or less then a 40A would be ok. if the wire is 7' long you'll either step up to 8awg for that 40A breaker or use 10awg with a 30.
Fk5 likes this.
Old 29 Jan 2016, 09:41 am
It's a 410W inverter with a listed max draw of 42 amps (though my normal max shouldn't ever be 250W, I just like buffer room). It will run from about the dash to the battery through the hood latch cable hole (unless a better path through the firewall is available, I just don't want to cut through the firewall) so that is probably between 8-12 feet each way. Right now I'm intending to use 12AWG wire, which the auto store said should be sufficient for this purpose. Any more information needed? I figured a 40 amp fuse/CB as that is below the inverter tolerance but above my requirements (300W/12V = 25A, and assuming an 80% efficiency means 31A, though the efficiency should be better than that, again I just try to pad).
Old 29 Jan 2016, 09:57 am
you should look at my chart and not listen to the people at the parts store.
my parts store buddy: http://www.ptcruiserlinks.com/forum/...rts-store.html
for 12awg 8ft long, i would use a 20A fuse. you're intending to double the recommended rating, and that's figuring you get away with 8' or less.
if you ever get a short in your wiring, you'll have a red hot 8' long wire slicing through your vehicle before that 40A fuse pops. i've been there, and it's no fun.
Old 29 Jan 2016, 10:27 am
if you HAVE the 12 already, the calculator here says:
running two 12awg wires is equivalent to a 9awg.
running three is equivalent to 7awg, which would be ideal.
a lot of car manufacturers do this. for example my 92 ford used two 10awg wires for the alternator output.
Old 29 Jan 2016, 11:14 am
here man, read this:
you honestly should just return the 12awg, buy thicker stuff, and do it right the first time. when all is said and done i highly doubt you'll ever say "i should have used thinner wire"
Old 29 Jan 2016, 12:43 pm
Attachment 15836
I will probably be doing that. Another question though, and this probably sounds dumb, but is there a difference between AC wire and DC wire? The internet says no, Home Depot guy said yes. I'm inclined to think wire is wire for the most part. If I just go to home depot and get some 6 or 8 gauge wire, is it going to be good for this?
Tags
electrical, fuse, tipm
tool to remove 3 slot antenna cap nut ptprice Exterior Accessories Forum 7 21 Sep 2013 07:03 pm
Why The Empty Posts? NightWing General PT Cruiser Discussions 8 23 Mar 2012 12:41 pm
Freon close to EMPTY! bobdole369 General PT Cruiser Discussions 12 26 Sep 2011 04:13 pm
HELP with Wiring Fuse 7 (No feed to fuse) No A/C, Electric Windows, Rear fogger??? ptcruisershoreham General PT Cruiser Discussions 3 08 Mar 2011 08:06 pm
