Steam coming out of vents in car
Old 29 Jan 2016, 03:04 pm
Angry UPDATE Steam & burnt smell coming out of vents in car
I have a 2001 PT Cruiser with 138K on it. It has been sitting in the garage for a cold winter about 4 or 5 months.
I took it out today and started it and took it for a ride.
Once the car got warm, smoke/steam came out of heater vents and smelled terrible. Inside windows got fogged up. Heat was coming out fine and temperature gauge was normal. I did not notice any leaks anywhere inside or outside. No coolant loss anywhere.
WHAT IS GOING ON? What would have happened sitting in the garage? I thought maybe condensation, but would that give a yucky odor with the steam/smoke coming out of the heater vents? If it were heater core, wouldn't there be antifreeze smell and leaking inside the car?
PLEASE HELP. This can't be. I had used the heat before putting it in the garage various times and nothing was wrong with the car when it was put into the garage.
Old 29 Jan 2016, 03:10 pm
Default Re: Steam coming out of vents in car
smells terrible as in coolant, or rotten eggs? or dead mouse?
Old 29 Jan 2016, 03:11 pm
Actually like burnt smell. burnt rubber or electrical maybe? yucky
Old 29 Jan 2016, 03:16 pm
Talking Re: Steam coming out of vents in car
Heater core.
Old 29 Jan 2016, 03:27 pm
how? why would it just go out sitting in the garage? doesn't make sense.....no fluid in car and no leaking.
Old 29 Jan 2016, 03:37 pm
i would think the steam and electrical burning smell are unrelated. i would see how it is after you drive it 2-3x before worrying.
Old 29 Jan 2016, 03:53 pm
not sure about that.
i smell it and then the smoke comes out as soon as the car gets warm. then the inside windows get smoky.
I came home and put the car away and the next day, the windows inside are fine again.
WHAT IS GOING ON>?????
Old 29 Jan 2016, 04:56 pm
Anyone try stop leak? does it work? Can it do anything bad?
Old 29 Jan 2016, 06:03 pm
Don't use a cheap one. The will cause you problems. You want to get Barrs leak head gasket repair. Type leak seal. Around 20+ dollars. Don't youse the cheaper ones.
Old 30 Jan 2016, 03:04 pm
I got the Barrs radiator/heater core aluminum sealer. I put in 1/2 as the bottle states to use 1/2 for 4 cyl. ran it like it said and i almost thought it was gonna work. for about the first hour, the smoke and smell had gone way, way down. There was only a little condensation on the middle of the windshield, but it was totally driveable. THEN........it started coming out again through the vents and fogged up the inside again just like before.
Letting it cool again, put it back in garage. MAYBE thinking about putting the other 1/2 in tomorrow and try again. I DON;T KNOW!!!!
Smoke coming thru ac vents SaraT General PT Cruiser Discussions 16 05 Jun 2018 08:14 am
Gasoline Smell coming in Heater Vents 2002 PT Limited MarcusO Tech & Performance Forum 13 18 Jan 2016 01:05 pm
2002 PT.. Cool Air Entering Cabin from Vents when AC System is OFF and Vents are off. Ptdave02 General PT Cruiser Discussions 2 12 Feb 2015 03:50 pm
Steam through the A/C vents hidinginparadise Tech & Performance Forum 4 26 May 2011 09:50 am
Always warm air coming out of the vents! ProDigit General PT Cruiser Discussions 9 27 Jan 2011 08:22 pm
