I NEED HELP!! 2003 PT
Like Tree3Likes
Old 01 Feb 2016, 06:06 pm
Default I NEED HELP!! 2003 PT
MY car will not start just a loud click....Headlights, radio etc work
-battery is from September
-alternator was replaced Nov 2014
This weekend
-brand new starter
-new battery terminals and cables
-brand new ignition switch
If I turn the key rapidly it sounds like its build up to start and I did get it to start once on Saturday. I drove it for 20 minutes, got home turned it off and it wouldn't start again.
Old 01 Feb 2016, 06:29 pm
Default Re: I NEED HELP!! 2003 PT
Have you tried checking your starter relay? Try switching your horn relay to the starter relay if the starter relay is clicking.
Can you tell us where the clicking sound is coming from? Starter Relay, Starter Solenoid, etc.
If you have a voltmeter see if you are always getting twelve volts to the Solenoid from the ignition switch.
When you replaced your ignition switch did you replace the actuator? Sometimes the pin breaks between the cylinder switch and the actuator. Its possible that this is why you were able to get it started by turning the ignition switch several times.
Handy_Cruiser likes this.
Old 01 Feb 2016, 07:05 pm
Thanks for the help
The clicking is coming from the solenoid
The pin, I'm guessing is the white plastic thing that sticks out and goes into the ignition switch? If so it's still intact.
I'll check the relays right now
I don't have a voltmeter
Old 01 Feb 2016, 07:13 pm
Switched the relays and there was no change
Old 01 Feb 2016, 07:51 pm
I would check the battery. The battery can still go bad as you don't know how old the battery is when you buy it unless you know what to look for on the battery.
Can you borrow a volt meter and a battery charger from someone?
Take the caps off the battery and see if the fluid need to be refilled.
Do the headlights dim when you are trying to start the PT Cruiser?
Did you buy a rebuilt starter and if so where did you buy it?
Old 01 Feb 2016, 08:00 pm
I had the battery checked Saturday and the starter was brand new.
I'll check into a voltmeter
Old 01 Feb 2016, 08:43 pm
You can get a voltmeter pretty reasonable. The link below is for Harbor Freight if you have one nearby.
Digital Multimeter - Save on this 7 Function Digital Multimeter
Old 01 Feb 2016, 08:51 pm
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 01 Feb 2016, 09:20 pm
LionPT's Avatar
This weekend
-brand new starter
Clicking is an electrical/starting issue...recheck all connections in bold above.
Old 01 Feb 2016, 11:56 pm
I will be doing that in the morning
2003 PT GT chuzz Classifieds: For Sale/Trade 2 10 Oct 2015 01:51 pm
2003 PT watsonmv General PT Cruiser Discussions 6 02 Jul 2011 03:00 pm
WTB: 2003 ATX S1 vr_junkie Classifieds: Want To Buy 0 30 Mar 2010 03:46 pm
New 2003 pt gt 2003ptgt General Turbo Discussions 2 14 Dec 2009 07:36 am
FS: 2003 PT GT reefblueGT Classifieds: For Sale/Trade 0 13 Aug 2008 10:35 am
