Cruise Control Issue
  • 1 Post By sanatanadharma
Old 04 Feb 2016, 11:39 am
Question Cruise Control Issue
Hello All,
I recently purchased a 2001 Limited edition 5 speed model with 70k miles for my son to drive to college. Seems like a solid car but the only issue is we can't get the cruise to work. Ive looked over the forum to try and diagnosed but so far no luck.
Symptoms: Cruse control does nothing. No light
Tried so far: Checked fuse #10, fuse good, car won't run without it.
Checked OBD, no codes
Disconnected battery to reset computer, no change
Opened back of CC pod to ensure plunger is engaging blue button
I am wondering if the ECM is bad, but shouldn't that throw a code ?
Any ideas ? Thanks
Old 04 Feb 2016, 01:55 pm
Default Re: Cruise Control Issue
Probably a stupid question, but have you checked the connector under the hood and tried to pull a vacuum on the servo?
Old 05 Feb 2016, 05:26 pm
Yes on the connector. No on the servo. Would that prevent the light from coming on ? I have a vacuum pump, is that how you test the servo ?
Old 05 Feb 2016, 07:07 pm
Because Trump
chuzz likes this.
Old 06 Feb 2016, 08:06 am
I don't think the servo being defective would prevent the light from coming on. It sounds more electrical. Follow Santa's advice. IF you pull the vacuum line off to put suction on the servo, be careful. They get brittle and break rather easily. Until you check the electrical and either confirm it or rule it out, don't fool with the servo.
Old 06 Feb 2016, 01:59 pm
I think my next step is to buy a service manual
Old 06 Feb 2016, 07:17 pm
Because Trump
Old 08 Feb 2016, 02:49 pm
Because Trump
Old 12 Feb 2016, 01:24 pm
Light does not come on prior to startup. could be bad cluster
Old 12 Feb 2016, 10:24 pm
_PTGT03's Avatar
take out the airbag, remove cruise switch and test for five volts at the speed select switch, and a path to ground for the ground wire.
Tags
cruise control, ecm
Cruise Control Issue - Stumper... TurboDucky Tech & Performance Forum 7 16 Sep 2013 09:11 pm
cruise control hillbilly678 General PT Cruiser Discussions 3 26 Jan 2013 06:34 pm
Cruise Control chasjr1450 Tech & Performance Forum 4 13 May 2012 07:15 am
Cruise Control blown05gt Tech & Performance Forum 0 17 Apr 2011 09:42 pm
Help please, cruise control adamw General PT Cruiser Discussions 7 30 May 2009 12:33 am
