Pt cruiser gt leaking coolant by firewall
Old 05 Feb 2016, 10:29 pm
philstad28's Avatar
Default Pt cruiser gt leaking coolant by firewall
Hey everyone! My 03 pt gt has a coolant leak somewhere by the firewall . It smokes really bad when I stop the car and there is a puddle under it. It doesn't overheat and still drives fine...even on 40 minute drives. I crawled underneath and couldn't see if anything was wrong. Could it be the coolant reservoir or is there a tube or hose I cant see? any info would be helpful
Thanks, Phil
Old 06 Feb 2016, 12:22 am
Default Re: Pt cruiser gt leaking coolant by firewall
Is the coolant filling up to the top of the coolant reservoir? If not check the coolant reservoir for cracks.
I would suggest physically checking the hose between the radiator cap and the coolant reservoir. Make sure the hose is tight on both ends. You might be getting air into the coolant system.
Old 06 Feb 2016, 01:18 am
When I got my 03 Dream it had a water leak that was a pinhole in the overflow tank on the firewall. Though I did epoxy the leaking, I ended up installing a new one.
I also replaced the heater hoses, radiator upper and lower hoses, and the sneaky little hose behind the turbo intake hose that feeds the turbo coolant line.
Old 06 Feb 2016, 07:59 am
Which side of the car is it on? If on drivers side, I'd suspect a heater hose. Passenger side, what Steve said. If you had a turbo and it's in the middle, I'd suggest the turbo hose by the exhaust.
Old 06 Feb 2016, 08:54 am
if not the overflow tank check the heater core hoses clamps and the core itself that accepts the hose.
Old 06 Feb 2016, 08:58 pm
philstad28's Avatar
Im going to look into it more tomorrow. Im leaning towards a loose hose or a crack in the reservoir. I noticed that the smoke is pouring out through the throttle body/ intake manifold. Its something I never saw before. Could it be a pcv or something? it smokes really bad. the car isn't overheating or anything either
Old 06 Feb 2016, 10:42 pm
Does your PT Cruiser have the turbo?
Leaking coolant - "Engine coolant pipes"? xkey General PT Cruiser Discussions 3 01 Jun 2014 09:11 am
Coolant leak near firewall ackermam Tech & Performance Forum 7 31 Oct 2013 08:44 am
2001 PT Leaking coolant PTCommuter Tech & Performance Forum 2 16 Oct 2012 05:33 pm
06 pt (A/C) leaking lots of water from the firewall at the ac inlet to interior steveohb Tech & Performance Forum 7 14 Jul 2009 08:00 am
leaking coolant near transmission pan pppt03turbo General Turbo Discussions 8 19 Feb 2008 02:14 pm
