Brake questions
  • 1 Post By rcktpwrd
Old 07 Feb 2016, 01:12 pm
Default Brake questions
I just changed the front brake pads. The left side had about half the pad left. The other side was bare. I'm assuming the right side caliper is sticking. The car pulls to the right even though I 've recently had it aligned. Could this be related
Old 07 Feb 2016, 01:23 pm
Default Re: Brake questions
There are 2 pads on each side - were both right side pads bare or one bare and one half worn? Could be a pad hanging up. If both are bare, could be a hanging caliper.
Old 07 Feb 2016, 01:35 pm
Both were bare
Old 07 Feb 2016, 02:42 pm
Either the caliper is sticking or the brake hose could be collapsing on you. Make sure you clean and lube the caliper guide pins too.
Old 07 Feb 2016, 04:12 pm
Could that make the car pull to the right
Old 07 Feb 2016, 04:23 pm
rcktpwrd's Avatar
a sticking caliper or bad brake hose will most definitely make the vehicle pull to which ever side has the good working brake.
chuzz likes this.
Joel
www.rcktpwrd.com
Old 08 Feb 2016, 08:12 am
^ What he said!
Brake Questions oldunclelar General Turbo Discussions 8 07 Sep 2009 06:26 pm
Drum brake replacement Parking brake cable Dorkygrin General PT Cruiser Discussions 2 28 Mar 2009 07:53 pm
brake questions 4SPEED Turbo Wheels/Suspension/Handling 4 15 Apr 2007 10:52 am
Rotor replacement and general brake questions purple people eater Turbo Wheels/Suspension/Handling 7 25 Jul 2005 08:54 pm
Brake Pad questions jmack General PT Cruiser Discussions 4 28 Mar 2005 02:18 am
