Please throw me a bone, this is weird
Like Tree4Likes
Old 11 Feb 2016, 11:22 am
Default Please throw me a bone, this is weird
Extremely cold last night. Went to warm up the PT and it turned right over and started. THEN, it ran for 5-10 secs and died. Repeated 2-3 times. THEN, turning the key produces nothing. Not a click or anything-ALthough all power systems seem to function. I assumed a frozen fuel line to be the issue so I cranked the heat in the garage and put charger on batt just in case.. I even disco'd the + cable in the chance that the ASD may have had something to do with it. Several hours later now, and the batt is fine. But turning the key, all I get is what sounds like the FP priming. Even if the fuel line is still frozen, shouldn't this thing turn over? I'd be thinking starter, but like I said, turned right over earlier. Please, any ideas welcome.
Old 11 Feb 2016, 11:30 am
Default Re: Please throw me a bone, this is weird
Is this a 1985 VW bug???
It helps if you first start by giving the information of the PT Cruiser...year model transmission etc.
Old 11 Feb 2016, 12:06 pm
2001, Auto, non turbo
Old 11 Feb 2016, 12:31 pm
I would suggest physically checking for electrical wiring problems.
Sometimes when someone starts working on a PT Cruiser they will pull on the wire harness and break a clip underneath the engine holding it in place. The wire harness falls down and starts rubbing on the half shaft. Go underneath the PT Cruiser and see if the harness wires are shorting to ground rubbing on the half shaft or the frame. Some members have had the battery not charging because of this problem. This is a common problem for the 2001 & 2002 PT Cruisers.
Old 11 Feb 2016, 12:41 pm
I checked this a while ago and the cables are tied up tight and clear. Again, the battery was charged this morning and remains charged. It's almost the same situation was when my ignition switch went bad. The car did crank and start this morning prior to charging.
Old 11 Feb 2016, 03:51 pm
Does it keep running if you are spraying starting fluid in the throttle body? If not try disconnecting the camshaft sensor wire and see if it runs.
Old 11 Feb 2016, 05:09 pm
Because Trump
Rondak likes this.
Old 13 Feb 2016, 10:48 pm
Its -20 here now so diagnostics on hold. But, I checked fuses-good. relays-good. I think next I am going to meter at the starter and see if power is getting through before digging too much deeper.
Old 13 Feb 2016, 11:16 pm
When you try to start the car, is the red security light on or flashing in the speedometer face? If so, it is the security system preventing the car from starting. You can try a spare key and see if it starts.
Old 14 Feb 2016, 12:50 am
+1
Your Immobilizer System might be locked up as Myckee posted.
Hook up a battery charger to the battery, turn the ignition key to the "On" position for one hour, then turn the ignition off and remove the key. See if that helps.
"Dog Bone" Bar / Stabiliser Bar... stek2008 General PT Cruiser Discussions 6 09 Nov 2013 09:14 pm
Motor Mount bushing replacement or Dog bone upgrade rspiegel Tech & Performance Forum 4 24 Feb 2010 09:38 am
PT Afghan/Throw 1stState Classifieds: For Sale/Trade 7 24 Feb 2004 11:41 am
Hey, let's throw North Carolina in the mix... IRPT General PT Cruiser Discussions 16 02 Feb 2004 09:26 pm
